Re: ver 2.4 beta 1 WIN/MAC 64 bit
I don't know, understand what this will be better, but to do this need spend a lot of time. I think it is future task, not 2.4 stage.
Have the pitch and roll problem in B2.  When I look at joystick settings, all the axis are moving so X-plane is getting the signal.
53
ivota wrote:
please reload x-plane
Still no engine sound.
I restarted xplane  several  time, but no e. sound.
Also renamed  folder "320neo_JARDesign" to "a320", same issue.
Also first loaded default aircraft then a320, same issue.
log is clear.. So are you have 2.3r4 work well (with sound)?
Yes, 2.3r4 work well (with sound). never had a problem with sound.
soooo.. beta 3 Should have both - sound and flightcontrol!
