1 (edited by J.A.Romanov 2015-05-27 15:27:26)
Topic: ver 2.4 beta 1 WIN/MAC 64 bit
So, we back to 320 improvement after a long 330 session.
Plan is make v2.4 with tuned FBW and PFD, next v2.5 with improve FPLN and ND part. Also (it may be some 2.4 beta we will add some visual changes in cockpit, very cool changes).
What new beta1:
+PFD tune
+FBW tune
+MCDU one step delete with CLR
+STAR RNAV approach draw fixed
Download link http://jardesign.org/a320/download/inst … V2.4b1.zip
  - be sure, what you use X-Plane 10.36 or later
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong.
If your activations are over (activation error) - use contact email from official website http://airbus320neo.com/contact/
Sure, important both - parameters and feelings.
Not need post some after one flight, take your time and make several landings, etc.
If you post info about CTD, please info are you have CTD any time when you load a320 or just once. If you post CTD info, please attach log.txt file.
If you have CTD every time, please rename a320 folder to short "a320" and move it direct to aircraft folder.
For some reason, no sounds at Windows at 90% of users. I know about this problem and wait solution from SASL developers
Re: ver 2.4 beta 1 WIN/MAC 64 bit
This is indeed good news!
Who can participate in the Beta process? Could I download and try?
Thanks,
Fabio
3 (edited by WoDi 2015-05-26 20:15:35)
Version 2.4 b1 installed und reloaded and no crash!
Great job!
regards
Dieter
Edit: no engine sound!
Thanks JAR for update.
Installed, but no engine sound.
All others sound works well.
I am going to test more.
yep problem with sound, but it is beta for test FBW and other new things smile
Ok. Thanks for replay. Engine sound not working.
A little strange to fly without engine sound. He,he..no problem. I hope you will be fix soon as possible.
Lets go test FBW.
Okies ... I get a CTD once activating the plugin - manually and automatically ... Error message is:
SASL ERROR: Error loading panel: not enough memory
I have 16 Gigs RAM and a GeForce GT 640/PCIe/SSE with 4 Gigs VRAM
Anyway, time to say good night for now.
Have fun and good flights
Great! Good Job thanks so much!
Great Thanks
- iMac Retina - Intel Core i5 - 3.5 GHz 16 Go DDR3 - AMD Radeon R9 M295X - Mac OS 10.11.5
- MacBook Pro 15" - 2.66 Ghz - Core 2 Duo - 4 Go  DDR3 - nVidia 9600M GT - Mac OS 10.10.5
- X-Plane 10.45r2]
Works great, but after shutting down the flight controls still stay available (rudder moves)
Lets go test FBW.
please reload x-plane
good day,
working good ... on mac ..
mine crashes..
24 GB ram 4 GB Gtx 980
Lawrence
Lawrence
Rename directory with A320, and try again.
if you have CTD just after activation, please, reload x-plane
if you have CTD any time you loss a320, please post your log.txt file just after CTD
and be sure what you are read well restriction page at official website http://airbus320neo.com/restrictions/ about 3-th part plugins
Lawrence
24 GB smile
it does not matter how much you have, course SASL may address 2 gb only. And as aircraft loaded last, it may be busy with all your installed plugins.
I don't know exactly course not see log. Also, yes, use name as in installation instruction (if someone read it) may help sometimes.
wow thank you very much , keep on updating the a320
Activation error...
Same issue! hmm
Lawrence
Worked! Rename the folder ONLY to 'A320'. NOTHING more. Just 'A320' and reload it.
FS Steven wrote:
Same issue! hmm
http://jardesign.org/forum/img/m/22/t/p19m940hi4147e13avgnk1safski3.jpg
[quoteJ.A.Romanov]
Lawrence
Renamed to A320 worked ,
Now its the sound issue , but the aircraft looks stunning
lawrence
No aircraft sounds at all for me. No sounds from engines, switches and fire alarm test, even reloading the simulator. The co-pilot sounds are ok, simulator default sounds ok too.
X-Plane 10.36
Win 8.1 64
16 Gb Ram
GTX 970
X-Plane 10.36
Win 8.1 64
16 Gb Ram
GTX 970
Try load default aircraft (ex. cessna 172) -> Reload sim -> Load A320 and try again.
For me sounds appear on second reload.
