CoPilot Plugin for ToLiss Airbus A321 (X-Plane 12)
Started by Administrator, May 28, 2023, 08:04 AM
Previous topic - Next topic
Administrator
CoPilotPlugin for ToLiss Airbus A321
REQUIREMENTS:
+ X-Plane 12.00 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ ToLiss Airbus A321 aircraft Version 1.4 + (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
(actual version 180123, ToLiss A321 version for XP12 compatible)
Pilot job in a modern airliner involves two people. As you are a simpilot, you need someone who can listen to you, execute your command, read checklists, live with you. You can get this with JARDesign Copilot plugin.
She name is Linda. She is well-qualified Airbus A321 (TM) F.O./copilot. She have:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
+ can execute SOP (Normal Procedures, limited)
DOWNLOAD:
This product is not refundable, but You can download, install and test the demo version (Manual included) right now http://www.jardesign.org/copilotdownload/XP12-CPL-321.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key here https://store.x-plane.org/CoPilot-for-ToLiss-A321_p_1238.html
SUPPORT: www.support.jardesign.org
Old CoPilot version for XP11 you may download here:
http://www.jardesign.org/copilotdownload/JD-CPL-321.zip
