CoPilot Plugin for Zibo B737-800 (X-Plane 11)
Started by Administrator, May 28, 2023, 07:54 AM
Previous topic - Next topic
Administrator
CoPilotPlugin for Zibo737 X-Plane 11
REQUIREMENTS:
+ X-Plane 11.41-11.52 flight similator
+ Windows OS (7 .. 10) or MAC OS (HiSierra .. Catalina .. BigSur)
+ Microphone or Headset
+ B737-800X (ZIBO mod) aircraft version 3.43 (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
Pilot job in a modern airliner involves two people. As you are a simpilot, you need someone who can listen to you, execute your command, read checklists, live with you. You can get this with JARDesign Copilot plugin.
She name is Linda. She is well-qualified Boeing 737 F.O./copilot. She have:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
+ can execute SOP (Normal Procedures, Limited)
This product is not refundable, but You can download, install and test the demo version (Manual included) right now.
Actual version (250622) link:
http://www.jardesign.org/copilotdownload/JD-CPL-737.zip
Old version (150222) link:
http://www.jardesign.org/copilotdownload/JD-CPL-737_220522.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key here https://store.x-plane.org/CoPilot-for-B737-800X-ZIBO-mod_p_1292.html
SUPPORT: www.support.jardesign.org
WHAT NEW:
250622
+ bug fix
220522
+ copilot logic improved
+ copilot movement improved
+ minor bug fix
090122
+ arrival runway identification fixed
+ "Ready for Secure Checklist" loop fixed
+ minor bug fix
171121
+ jetway power recognition add to electrical  power up procedure
+ add AC BUS recognition logic at electrical  power up procedure
+ NAV 2 drew input improved after Only Cat 3 Command
051121
+ electrical power up procedure auto start fix
+ electrical power up procedure GPU issue fixed
+ preliminary preflight procedure improved
+ preflight procedure improved
+ ILS freq set command add for CAT3 approach
+ add fast reject/abort command (may be assigned to button)
061021
+ plugin scripts was fully reworked
+ add "one button control" (please read manual)
310321
+ minor improvements
190221
+ Taxi Light switching logic improved
+ Transition and Approaching Transition logic fixed
+ Logo Lights logic add
+ Windows Heat logic add to electrical power procedure
+ Cockpit door logic add
+ Descent checklist "minimum" logic fixed
111220
+ Runway turn OFF lights command fixed
+ add Engine anti ice on/off command
+ add Wing anti ice on/off command
+ add APU off command
291120
+ bug fix
291020
+ altitude issue fixed
+ deicing checklist/procedure add
141020
+ random events add
+ landing rating add
010920
+ After takeoff checklist freeze fixed
180820
+ Initial release
