Re: [STABLE] v.1.2r2 (Win 7/8, MAC OS 64 bit)
Much better version !
Here is the bugs I found after the first try:
1. Track selector unable after FD off. So that unable to select downwind leg track when visual approach.
2. The ground power button: the left button is "Auto", not "On". Since in normal, pilots only push the left button to "OFF" and left the other "Auto". Then it will distinguish after the ground power unit removed.
3. The APU start takes much longer time.
4. The flight plan page: The "To Way Point" and flight page should be sequenced after "DIR to some point". Besides, The ND doesn't show up the change in amber dash before inserted. This is a big problem that the pilot will have no idea where is he and the plane to go.
5. I took of before IR alignment completed, but everything is still fine, ha~
In the end, if the player can change KG to LBS will be good.
