Re: XP11 JD330 v.3.1 r1, r2, r3
Mr.JAR, nice to meet you.
I have just bought JD330, as you can see from the attached pictures.
But, once I run 330 in XP 11, the content in pictures goes like this
and it leaves me no option but to quit the XP11, no window for me to type in Serial Key.
Could you tell me what the version of 330 that I bought is? from simmarket.
I have just installed the file named 330 XP-11, I have NOT used the other filed which is named 330 only, which I think might be for XP 10.
Erase all and install the last version at the first page of this thread, the last version V 3.1 r3 plane and the groundhandling plugin.
I'm having the exactly same problem. Using SkyMaxx.
i7700 / 16Gb / GTX1070Ti
divinglyc wrote:tsute2 wrote:Are you using ASXP? If so, the METAR doesn't read for now.
No, I use default weather of XP 11.32.
Thanks!You must press update, and you see.
I'm having same problem using SkyMaxx. No metar.
Would love to have curved route lines. Does anyone know anything about this?
Jardesing, Please make some updates or add some new things, you guys are not even completed a330 perfectly and started making a340 so funny ))
When will A330 co pilot be released?
Kind regards
Steve
Kind regards
Steve
http://jardesign.org/forum/viewtopic.php?id=11425
Thankyou
Dear Mr. JAR
I've purchased A330 by JAR Design and found many unrealistic in FMS programming.
Do you have any plan for improving it, such as SEC Fpln, Store Route, Store Waypoint and many complex function for FMS such and Place/bearing/Distance function?
if yes, it would be great for every pilot who need to use it and practice tool for advance flying not just people who what to enjoy the graphic of gaming.
I've try aerosoft a320 in FSX and the FMS programming is very similar to the real one although the time pass long ago.
Could you please improve it at least equal or it would be great to be much realistic than the above i mention one?
Dear Mr. JAR
Do you have any plan for improving it, such as SEC Fpln, C such and Place/bearing/Distance function?
What do you mean by" Store Route, Store Waypoint and many complex function for FMS" ?
and "Place/bearing/Distance function" are already visible .
Are you sure to program a flight as it is required ?
pingkortod wrote:Dear Mr. JAR
Are you sure to program a flight as it is required ?jcdp
In FMS > Data > second page, there are function such as Waypoints, Routes, etc, all of these function of my JD330 is not working. I'm not sure that it was only me or not that this function was disable. normally these function is used as adding new point references from Lat/Long , Bearing/Distance from the existed point to the database.
on 2L button of the F-PLN page normally should have "Fix info" that can bring the saved point from new added way point to be appear in Navigation Display, or to add it as abeam point in Fplan and can also use the direct function from these point but now very limited function can be used.
Sec F-plan is also not available for me now, just a static button that pressed and show nothing.
I've capture the picture but i'm not sure how to upload it since the forum is really limit the sized of the uploaded picture.
please check the link below, this is the function "Fix info" in mention.
https://forum.aerosoft.com/index.php?/t … -to-guide/
jcdp wrote:pingkortod wrote:Dear Mr. JAR
Thanks for your explanations .
Sec F-Plan has never been available …
You are right 2nd data page is currently useless …
It could be interesting to have all these possibilities implemented .
pingkortod wrote:jcdp wrote:Hi
https://forum.aerosoft.com/index.php?/t … -to-guide/Hi
You are right 2nd data page is currently useless …It could be interesting to have all these possibilities implemented .
Are you in Dev team ? or if you are in dev team, Dont you guys think to make a330's other versions(330-300 and other engines cfm or PW or maybe a330-800/900 ??
To Mertivic23
No I am not …
But I like this aircraft and I perfectly agree with your comments .
Hope that JAR design improves this nice aircraft .
They are focused now in to shell another plane, the a340...
I have a problem when turning on the rain effect...see picture
if you are on a Mac you are out of luck. doesn't work on Mac OS.
If this not work well, you may you may disable rain window at MCDU MENU -> SETTINGS
Great answer sir...
When release Update 3.2?
and
what about the a340?
Very Great Support from jardesgin Nothing no Answer nothing. Never fly Jardesgin. Dear mr. Romanov I would like to think if there is a future for jardesign.
175 2019-06-10 17:33:45 (edited by jcdp 2019-06-10 17:38:31)
Support is not on this forum …
Explain your problems on : http://www.jardesign.org/ticket/kb/index.php
