Re: X-Life ver 2.1 beta 3,4,5,6,7 (add real schedule)
another crash during takeoff from EDDF (pay), in attach rar file with log and x-life.dmp
Thanks in advance
JARDesign Group Board → Updates & General Discussion → X-Life ver 2.1 beta 3,4,5,6,7 (add real schedule)
Thanks in advance
Sometime the real schedule became crazy (for example an EZY fly form Auchland to Liveripool vith a319) but for the rest this new functio is a milestone and i'm very very happy, thi plugin grow very fast and have great future.
Happ new year
Had a crash of X-life during flight from LFSB to LFML.
Find dump and log attached.
Hello
X-Life 2 times crahes in LSZH.
Happy new Year
Try to use Flywithlua complete edition and not the core edition
Thanks for reports. Just take all .dmp files for check and fix in next beta.
X-plane 11.11 and X-life 2.1b5 unknown crash dont know why, yesterday late evening same thing, crash in airport.
ver.2.1 beta 6 posted: http://jardesign.org/forum/viewtopic.ph … 234#p19234
+ fix some bugs and CTDs
+ share datarefs about ATC position/state for ATC-sound plugins (expect integration)
Thank you! try now..
I've still the CTD when try to open airport editor in an airport not compatile with xlife. I've only the log.txt because the x-life.dump is not created
Thank you for update testing now
Today i'll try to fly from LJLJ t EGLL few times with x-life. Five times in the morning x-plane crash with x-life version 2.1b5. Everything looks ok. I set flight plan in flight computer, starts x-life, import plan to x-life plan from plane and then send to ATC. All green lights and looks fine, but then crash.
I'll try with version b6 in the evening, but crash again.
X-Camera cause my simulation to crash. Maybe you should check all your plugins for compatibility. Deinstall them and reinstall one by one....
Darko24 wrote:Today i'll try to fly from LJLJ t EGLL few times with x-life. Five times in the morning x-plane crash with x-life version 2.1b5. Everything looks ok. I set flight plan in flight computer, starts x-life, import plan to x-life plan from plane and then send to ATC. All green lights and looks fine, but then crash.
I'll try with version b6 in the evening, but crash again.X-Camera cause my simulation to crash. Maybe you should check all your plugins for compatibility. Deinstall them and reinstall one by one....
Thanks for try helping me. I'll try without x-camera, but in this flight LJLJ to EGLL crash even without x-camera. It must be something other. X-camera never make trouble to me. I'll fly today to EDDF and then to LSZH with camera and plans from FMC sending to ATC with no problem. I'll even try to generate flight from x-life planner, but the plan is not created - still problem with open space over Slovenia and Austria.
Now I go to EDDF and from EDDF to EGLL
Log cant help. My skype j.a.romanov
You may send me airport what you try to open and describe situation there.
Just trying to read dump under debugger.. need a little time..
If this crash is stable - please contact me direct via skype j.a.romanov if this possible
2.6b CTD on approach to KMCO when asking for vectors not sure if .dmp file is correct as today's date is 1/5/18 saved from previous was 12/15/17
Is it possible to change flight level during the flight?
One question: Is it possible that BLUEBELL make an update for his A319 and A320 with latest paint (new color) of Eurowings (EWG)!!!
The A319 has old color and the A320 by EWG is not present!
Greetings and all the best for 2018 with this great plugin called X-LIFE DELUXE!
PS: I have the A319 and A320 with new colors by EUROWINGS (EWG) for the Bluebell X-Life collection.
If you want these repaints too please send PM to me.
Another question:
The Bluebell collection have one paint for each aircraft. Some airlines use more than one paint like Norwegian, EasyJet and so on. Is it possible to create more folders in the Bluebell collection for use with X-Life...like B738_NAX_paint1 or A320_EZY_paint2??? Thanks for your answer....Thomas
Ok, on next step (beta 7, posted) we add integration datarefs for Mark Ellis X-ATC-Chatter plugin what allow to play background ATC sound. So, we expect new version of X-ATC-Chatter plugin with this function in nearest future.
Hi Thank for update i will try.
hi x-plane 11.11 x-life 2.1b7 CTD when call FMcar in KBOS departure i add flies
hii just downloaded Beta 7 . When i turn on Traffic it tries to turn on but it doesn't start. i cannot enter flight plan. IS this just happening to me ?
Just got the latest beta version and finished creating new atc routes for KSJC.
Things ran fine for 10-15min but as a plane taxied behind me the game became unresponsive and crashed.
I'm hopeful that it has nothing to do with my airport routes but if you suspect it is check it out here: http://jardesign.org/forum/viewtopic.php?id=3698
On the bright side, traffic is absolutely spot on for the region!
