Re: JD330 Airliner ver 2.2 RC1, R2, R3 WIN/MAC 64 bit (X-Plane 11)
TDPlane wrote:
ComRPM wrote:
After some weeks without the E46 teleport yesterday it comes again ruining a Vatsim flight. The erase of the folder dont avoid the problem. Always after initiate the descend from TOD.
Is JAR the solely developer with this problem?
We work very hard on version 3 of JD330 with new FMGS, what will be independent of X-Plane flight computer. Anyway, this will be C++ (not SASL system) based part. We expect no issues like E46, cause we not deal with X-Plane navigation API.
Great news. Let me know when to test fly the aircraft ...
As soon as we get stable and flyable - will do. More than 50% of 330 code is new. Sure, test versions will be publish first.
Airbus is all I fly...
I'll take a test version anytime. Flying your airbuses from the beginning...
Thanks for being here.
Cheers  Hervé
Great news Mr. Romanov. Your 330 with the BSS sounds are the most inmersive plane of XP, at least for me. If you achieve to clean some bugs of present build this bird could overpower the new FF 320.
This plane is pretty cool, that is the truth !
However, I've a question :
When I want to do a flight between Zurich and Miami, I need to insert ETOPS information in the MCDU. So I put LAT/LONG information to create a new waypoint. After that, I click on the waypoint but I can't find FIX INFO. I would like to draw a circle to see ETOPS and airports in the circle...
Is it possible now ? Or in future versions ?
80 (edited by Scania_V8_Rat 2017-11-18 15:57:04)
Hey Eugeny,
because a v3 of this cool ACFT is planned, may I make a few suggestions what could be implemented?
  • Abnormal Procedures Complete Checklist (e.g. for All Engine Flameout etc.) in Airbus Style (I did one yesterday and I think you're on the right way with announcements etc.
  • Separate thrust levers with 2 axis to assign (to benefit of more than one thrust lever) and Idle reverse
  • better implementation of transitions after stars (but you mentioned before that you're going to do an FMGS rework
  • More (I want it to be as real as possible; it's already great) realistic FMGS system, e.g. with Alternate Airport options
  • More working buttons on the overhead panel (EMER GEN) and correct illumination of some buttons when alligning the IRS
But for know: thank you for this pretty cool plugin, system depth is (til now) not at full sutdy level, but I think you can make us happy with a v3
Happy landings
Yannik
Intel Core i7 6700k @stock - 16GB G.Skill Ripjaws V @3200Mhz - MSI RX480 8GB Gaming X - MSI Z170A Gaming M7 - beQuiet! Dark Rock Pro 3 - Windows 10 Pro (64bit) - SanDisk Ultra II 240GB SSD - 2TB Seagate Enterprise Capacity SATA - X-Plane 11 - JARDesign A330 - BSS Engine Sound Pack RR Trent 700 - AutoGate - Better Pushback - Ground Handling - SimCoders Headshake - TerrainRadar -X-Life - X-RAAS -
And a more friendly menu for manage doors.
82 (edited by ilankrt 2017-11-28 13:44:37)
Yesterday I was simulating a flight between YMML and YSSY Australia. Beginning with the approach to YSSY under usage of X-Life I flew into a crowd of airliner making their turns around the airport. I had ever seen such a number of AI aircraft under X-Life......
At this moment I felt a bit under pressure thinking how to deal with....
http://jardesign.org/forum/img/m/1591/t/p1c01docn2okgth2dom1r1k1bo74.jpg
83
Will A320 benefit from any of the improvements you implement for A330?
Is anyone having problems with sounds on the a330 after this new xplane update?????
JGomes
mdsh2080 wrote:
HI, I want to know when you are going to release the new version? (V3)
..."would like"  would be better ... and "Please " is missing ...
if you expect an answer ...(Education ?)
X-plane 11.20Vr2
86 (edited by shamanitou 2017-12-21 14:06:30)
Hi Eugeny
since the update V2. 2R2, to correct the sound issue, me and 3 of my friends we are having the same issue when we start to descent (auto managed mode) after the TOD, the right engine just shut off. even if we can start it again, it will shut off 1 to 2 minutes after again.
thank s fo your anwser.
JJ
Hello
the same problem as Shamannitou, Xplane 11.11r2 (build 111101 64-bit)  JD330 V2.2R2
2 minutes after TD the engine right shut down, without alarm, we can start it again, and shut down again after 2 minutes,
As dackar2 and shamanitou I've the same issue with the A330 2.2R2 with xplane 11.10r3, 11.11r1 and 11.11r2. the right engine shut down during the descent and after restart EGT value (for the right engine only) is not available
Same for me. I know this when leave the runway and initiate taxi to apron. The plane cant roll straight. But I can restart the engine with the EGT value off.
Hi, this is very interesting news. As long as this issue is not
solved I will abstain from buying this bird.
I don't want to throw 60,00 $ into the garbage.
Cheers
Bernd Schwarz
91 (edited by jcdp 2017-12-23 10:40:41)
Is possible to have log.txt, please ?
PS: with the same installation as yours I have not this issue .
X-plane 11.20Vr2
You have a problem or a question identify yourself, otherwise your complains will be transferred  to garbage !
-  Scroll to top of page
-  Choose from blue raw "Profile" open it
-  Choose from second blue raw "Signature"
-  Compose signature: write all info about hard and software + plugins you use
-  Update profile
Now we are able to know about your simulation environment
-  Send us for every question your log.txt (in the main X-Plane folder)
You might now get help or advice...
Writing a question without further information has no chance to be solve !!
93 (edited by ilankrt 2017-12-23 23:40:30)
Hi Jar, I just installed version 2.2R2.The default 3D pilot sit view is incorrectly (nearly in the middle and too hight) can you please correct and offer us a new .acf file? Thanks.  OK I changed myself the captain sit view using Plane Maker.app.
This version is unfortunately more unstable than 2.2.rc1 I used to fly until now.
-  Tailwind 8kt at 25000ft and airliner is shaking
-  On MCDU  PERF pages didn't change as it should during flight (CRUISE, APPR..) and stayed all the time on CLIMB !!
- GS was caught at a wrong FL (above FAP)
Just had a great flight in the JD320 from KSFO-KRNO, no issues.  2.2r2 and xp11.10
95
Just flew from EPGH-LIPZ in the V2.2 R2 A330 with only one minor problem. Optimum altitude was initially FL385. After I'd burned off enough fuel the optimum altitude was FL410. I couldn't enter a FL higher than FL400 in the INIT page, and I couldn't enter a FL higher than FL390 in the Perf CRZ page.
96
Hello everyone I would like to know how to upgrade the serial key from x plane 10 to  x plane 11.
Thank you very much
I really don't know why periodically such complains occur on this site. Question: Why do you want forcibly fly at limit ?  Where from do you get the optimum FL?
I don't know if JAR MCDU is calculating all parameter correctly, but fuel is only one factor.
Wind, Temperature. Cost Index are further parameter in the calculation......
Be happy fly at 390 FL, then there is no need the whole discussion...
Thank you very much
Buy upgrade from JAR ...
Flight from LFBD to EGLL with 330 2.2r2, no real problems with the flight. Small problem on landing, no warning sound when turning off the autopilot and no callouts on height or retard.
100 (edited by ilankrt 2017-12-28 17:19:43)
2 crashes because of SkyMaxxPro! It maybe in conflict with other new plugins like BetterPushback or X-ATC-Chatter, but developer says it is because overload of my graphic card. Personally I don't think so, because everything runs quite fluently at 30 fps.
Do anyone know about graphic card performance plugin for iMac?
Has anyone experience same problem?
BTW this happened after updating  to XP11.11
