Re: JD330 Airliner ver 2.2 RC1, R2, R3 WIN/MAC 64 bit (X-Plane 11)
Salut, mes master sw/start restent activés pour moi en 2.2r1
Cdlt
Salut
Bon voila j'ai fait une tentative, à tout hasard, de recommencer un nouveau téléchargement de la version 2.2 RC1 et une réinstallation, j'ai bien fait çà fonctionne.
Salutation
53
Hello Ivgeniy
sorry but rc1 not working, I have less time to look after this issue. but sometihg goes wrong. I couldnt manipulate some knobs like start apu or fmc.
I have xp11.05 installed. all is on correct place. So I try to install the older version.....
regards
Volker
I purchased the a330 PW and RR engine sound packs.  They work well.
I am wondering if their is a plan to add the actual engines to the plane.  Sounds cool / looks not.
I love the choices on the a320 for engines.  Is this going to be added to the a330?
2.2 RC1 and XP 11.10 b3 no more 3D sounds.
after I updated x-plane to 11.10b3 I faced to some issue as below:
1- Sound does not work I solve it by plugin admin
2- when I started approach the second engine did not work correctly and the plane missed the yellow hydraulic
3- can not increase the fuel from loadsheet
4- frame rates decrease
5- cockpit light does not work
http://jardesign.org/forum/img/m/3067/t/p1bsjq6s00abc14g04507fmsia3.png
http://jardesign.org/forum/img/m/3067/t/p1bsjqb4745vs184tqg6vt1174713.png
http://jardesign.org/forum/img/m/3067/t/p1bsjqepvs121t1dld1vnoc98j1v1n.png
57 (edited by jcdp 2017-10-17 09:37:54)
11.10b3 is a beta version ...for beta testers ...(are you X-Plane beta tester?)
So do not expect any change before final 11.10 stable release version .
Haven't been able to complete a full flight at all in this plane yet due to the spoilers. They just don't seem to work at all when I set the lever in any position. They work perfect on the ground but as soon as the bird is in the air, the spoilers do not want to do anything at all. The FO gives the callouts saying "spoilers half" and "spoilers full" but they don't deploy.
Using the plane on X-Plane 11.05r2.
59
Another E46 problem its really annoying!!! I was flying (LEMD-SVMI) 9 hours of flight and i had this problem, now today i was flying (GCLP-LEMD) 3 hour flight and again the same problem.... I can´t do long hauls is there any Autosaver to XP11? like the FSUIPC Autosaver to P3D/FSX.
I've also had this problem. And as far as I'm aware, aircraft that run on plugins can't be saved as a situation, the aircraft will just load in a cold and dark state, so will just plummet to earth.
61
Erase the folder Navdata into custom data/GNS430 and try it for the error. I erased it and no more E46 teletransportation error.
The problem with this method is that you will cause problems for other aircraft that use that information in that specific folder, i.e. Flight Factor planes.  Since JAR uses its own Navdata folder, why would this be an issue?  Just wondering.........
After some weeks without the E46 teleport yesterday it comes again ruining a Vatsim flight. The erase of the folder dont avoid the problem. Always after initiate the descend from TOD.
Is JAR the solely developer with this problem?
64
That is up for debate.  Some have said that they have experienced it with other planes, i.e. Flight Factor but I have only experienced it with the JAR A330.  Laminar said that it was due to having a controller button set to "reset flight" and when I told them that it wasn't the case, they never responded.
Its called ping pong. Laminar-Jar-Laminar-Jar-Laminar....
We work very hard on version 3 of JD330 with new FMGS, what will be independent of X-Plane flight computer. Anyway, this will be C++ (not SASL system) based part. We expect no issues like E46, cause we not deal with X-Plane navigation API.
67
Very nice news ...
Nice to hear! I knew you wouldn't sleep under a rock. I will stick to JAR Design for sure. It's been silent for a while, but I'm sure they deliver really good when it get's there.
Can we hope for a discount upgrade?
We only can hope that the 3.0 A330 version will be so good that it will take the wind of the wings of the FF enthusiast....
Thanks sir! I stopped flight your bird until V3. Dissapear suddenly from Vatsim radars its no a good stuff...
71
To use all the views I have saved previoulsy, can I copy the old "A330 prefs" from my previous 2.1R1 into the updated 2.2R2 one?
Or is it possible to just copy the content of the old prefs txt.data into the new one?
I would not do that, but you could use Notepad++ or some other tool and just move the views over to a new pref file.
Easiest is to use WinMerge
73
Great news. Let me know when to test fly the aircraft ...
74
Will be free Upgrade for "330 for X-Plane 11" users.
As soon as we get stable and flyable - will do. More than 50% of 330 code is new. Sure, test versions will be publish first.
