A320 v3.0b3
Update on my last notes (no73).
Flew EGCC - EDDH, engines did shut down correctly...  annoying airbrake only flipped up once.
Had a lot of problems setting up the EGCC SID and certainly the EDDH STAR in RIBSO (runway ILS23 - RIBS4A - No Via)  I kept getting "CL" which would not CLR? to join up the STAR to the flightplan...  Only way to program the MCDU was to just use the waypoints (fixes) as DEP or ARR routes to each of the runways.
EXT PWR was on the whole route?
SD
hdespres wrote:
Just noticed QNH on the FMS adjustment knob is not equal to the MFD value???
Yep, same here, happened yesterday when switching between 0990-0991-0992mbar  i got a different reading between mfd and the mcdu
BR
Latest beta update to XP11 broke the a320.  Engines will not start.  Seemingly no ignition, also start valves appear stuck open once engaged, cutting off apu bleed is the only way to stop the start sequence.
Using a320 V3 B3, latest XP11 install.
Thanks for heads up think i will pass dont want to mess up Neo
After updating I can't start engine one anymore. It seems, something is blocking fuel flow. But I can't find the error.
I confirm the preceeding post, engines not starting with A320 in X-plane 11 B12.
Updated the xplane 11 beta today and now the a320 engines do not start everything else seems to be ok but when I pushback and go to start they seem to start but n1 only goes to 1.3 and nothing else just wondering if anyone else had the same problem
108
Confirm. Laminars broke something inside beta 12 one more time. FUCK! Just a FUCK!
LR need to fix this not you... FF aircraft have same problems
110
Same problem, A320 engines wont start and tried other aircraft and similar strange issues with beta 12
111 (edited by rsvette12 2017-02-24 19:27:28)
F#$K   J.A. lol   good one - I will stay where I am at XP B11
112 (edited by lrpru29 2017-02-24 19:29:52)
Same problem that "ScottFDNY" engines in N1 do not go from 1.1%
In EGT  5º
In N2 28.7%
In FF 0
Please solve problem
113
No worries, we all know that this is beta software (both a320 and xp).
Is that something you will have to fix or is the problem on x plane side?
cheers
XP11 beta 13,  A320 3b4, Windows 10, GTX 1070, Intel Core i5-6600K @ 4.3GHz
114
If Laminars start to rework engines system - this is very expected pizdec, and this  happen now. Ok, will try to understand a reason tomorrow. Anyway, sorry, dear pilots about this troubles. Sure, this is beta stage and everything may happen.
115
Have a good night.. get some rest. Cheers
116
Don't worry, J.A., Beta is beta I'm sure in this moment of tranquility everything will be sorted! Goodluck!
Goodnight everyone!
Be patient ...... yes its a shame with this never ending  betas of laminar.:-)
But I fly on xp10 with 2.7R1 Really good. thx.
regards
118
Just so you know! I updated both the A320 and the A330.  The A330 works fine in X-plane 11 PB12.  This one has problems with the engines or Hydro.  I tried to open flaps with default keyboard #2 (would not open, just kept saying flaps "0").  I tried using Key #1, (Nothing happened period.  Keyboard key number #1 did nothing.  This started with PB12..
Updated A320 to version 3.0 beta Feb-23-17. The A320 worked perfect. Today Feb-24-17 XP11 was updated Ver 12. Cannot Start Engines Cold and dark or Hot. Engines reach about 28% then freeze. I have to restart Xp11 and try again. But no success.
120
Also here.
After beta 12 I can´t start engines. It sounds "starting engine one" but nothing goes on.
I have a problem with the A320 B3 in PB11. When adding fuel with the fuel truck, the sim freeze for like 2,3 sec each time I press the 'up' arrow. It's quite annoying if need to put 8K fuel... Didn't saw other complaints about it. Does someone have the same issue?
122
XP11beta12 issue fixed. Please redownload a320 to get beta4
Thanks a lot
124
Thank you much for the quick update!  Much appreciated.
125 (edited by WoDi 2017-02-25 10:52:20)
b4
SASL error: [SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
Edit: A new flightplan and the error was gone.
