Re: X-Life ver 1.2
simnut wrote:
I have the latest xlife installed with my X-plane 11 and works very well.  Only one problem I have.   I seem to get flashing green lights from some of the AI aircraft as in the pictures below.  They appear to be navigation lights on some of the aircraft.....far removed from the airplane though.  Anyone can tell me what is up? Thanks in advance!
http://imgur.com/a/KJTE3
http://imgur.com/a/Dwkqm
X-Plane "feature" of current beta.
Re: X-Life ver 1.2
Some sentences go out of window.
http://jardesign.org/forum/img/m/1506/t/p1b61i3gvm1rtk1qrdggtipnnlk3.jpg
Re: X-Life ver 1.2
Big problem with qnh !
The ATIS page give wrong qnh. (or ATC)
I look on ATIS page, enter the qnh, then, on clearance delivery, ATC say wrong qnh (and give me another qnh via voice).
Each time i use it, it make same error.
I add: i have SkyMaxxPro with RealWeatherConnector.
Re: X-Life ver 1.2
I had a similar experience. I got "Wrong ATIS" even though the QNH was at the correct setting, even according to ATIS. Then I requested again, with the same setting and got cleared. Also using SMP4, RWC1.1, NOAA and Venturasky.
30
Re: X-Life ver 1.2
I copied the X-Life update to my Xplane 11 folder where my original X-Life existed. But it looks like VER 1.2 is not starting. ONly the previous version is starting?
Re: X-Life ver 1.2
Would it be possible to increase the airtraffic density (more than the 150%)? On large airports I'd like to have more active aircrafts, like in reality.
greetings,
mika
Re: X-Life ver 1.2
Runway 35L at KMCO. Planes not moving for no reason. No planes on final approach and the runway is clear. Possible problem with logic? Using latest version 1.2 Vectoring works great thanks!
Re: X-Life ver 1.2
Re: X-Life ver 1.2
Why can't I see Lufthansa or other European aircrafts on European airports?
Re: X-Life ver 1.2
To my regret, the cooperation with JAR as designer has fallen out of the frame.
1. With the transition to XP11 is not clear any more are still making test flights with XP10 who has already has changed to XP11.
2  It is also unclear which aircraft model to be tested are compatible with XP10 and which were developed for XP11.
3. The test rubrike is transformed into a general mix of questions and answers, so it is difficult to separate the one from the other.
4. Clearly, however, the effectiveness of the test flights suffers and the developers usually get no useful information. Several test reviewers who provided much valuable information have simply disappeared in the last time.
5. In order to counter this negative development, in my opinion, a strict separation of test flight contributions and general questions must be introduced
36
Re: X-Life ver 1.2
AI traffic has no strobe lights, any ideas?
37 (edited by jcdp 2017-01-21 20:47:38)
Re: X-Life ver 1.2
Report:
Using XP11 b8 and A330 v2b4 I noticed that  "climb/crz/desc"   profile has disapeared when trying to get it on screen .
In flight plan generated with x-life there is no more altitude ...(could be the reason ...)
Attached log.txt
PS:so of course no TC nor TOD in flight plan .
Re: X-Life ver 1.2
Flying from LOWS to LFPG -> CTD while taxing to ramp in LFPG (see log)
Re: X-Life ver 1.2
Hello! Tell navigation data must also be updated in the traffic navigation data to be taken from GNS430?
40
Re: X-Life ver 1.2
would it be possible to add possible ground crew operations and to have the ai traffic comms come through as well I can only hear what I say and not the AI or is there a setting I need to change
41 (edited by Watauga 2017-01-25 03:54:54)
Re: X-Life ver 1.2
In preparation for a flight from KLGA to CYYZ the flight plan will not go over to the ATC.  The following message appears on the screen "Flight Plan error: Departure Airport Error" and the ATC stays blank.  See the first screen shot. I then hit the ATIS tab and the weather information is filled in, but the flight plan still does not go to the ATC.  See second screen shot.  Delivery, Ground and tower do not respond.  When I become airborne the ATC becomes active and functions throughout the rest of the flight.
I am using X-Plane 10.51r2 and X-Life 1.2r2.  Log.txt is attached.
I have both the dat and txt files for these two airports in the X-Life airport folder.  These were obtained from the Custom ATC routes on the X-Life web site.
This same situation has occurred for other flights since updating to X-Life 1.2r2.  At first I thought I was doing something wrong.
42 (edited by TKurzweg 2017-01-26 20:31:01)
Re: X-Life ver 1.2
What problem is this ?
Standing on airport LFML - Marseille Provence and spotting the x-life traffic. Everything works well.
Next aircraft is starting to UKBB (SAS A320). After takeoff the aircraft turns right and lost the altitude from 1.600 FT to -3.200 FT!
Waiting for the next aicraft (B767, Air Canada). Starting to UKBB...or UBBB same situation, after takeoff right turn and lost altitude! All the aircraft with other destination make also left or right turns after takeoff, but they fly correct!
What could it be?
Thx for your help !
43 (edited by bitje 2017-01-27 22:45:02)
Re: X-Life ver 1.2
1. How can be seen that this is version 1.2?
2. Why is the file not given e number?
Now I have to spit in the files. I renamed it xlife060117.zip
44
Re: X-Life ver 1.2
Continue to love this product, thanks JAR!
Could I ask for a feature request, so that I can specify an arrival airport that is within 100nm of my present position, and activate that airport, so that there is a good amount of arriving and departing traffic at my arrival airport when I get there?
Thanks SO much for your consideration!
Bill
KGSP
45
Re: X-Life ver 1.2
Are there any plans in the future for a version to work on Linux?
46 (edited by kebs 2017-01-31 13:21:06)
Re: X-Life ver 1.2
with A330b4  XP11 b9, xlife 1.2  trying to make a flight plan  LFPG/KJFK
when I export it to FMS, total distance 16453 NM
Same FP in Simbrief 3453 NM
Same result when I create a txt file in flight plans/plane folder.
Someone has an idea ?
Osx Sierra
XP 11 b9
A330 b4
Xlife 1.2
Airac 1701
Re: X-Life ver 1.2
kebs wrote:
Osx Sierra
XP 11 b9
A330 b4
Xlife 1.2
Airac 1701
LFPG is not a regulated airport in X-Live (I couldn't initiate traffic)
Inserting the FP from SimBrief  (go to Download page) into the FP folder of A330 and initiating it in the FMCU and the distance appears correctly..... 3380nm
48
Re: X-Life ver 1.2
you can find LFPG custom route and initiate traffic
http://jardesign.org/forum/viewtopic.php?id=2715
so normally i should be able to make LFPG - KJFK route without  simbrief no ?
49
Re: X-Life ver 1.2
1 Traffic at some uncertified airports don't work.
2 A route plan is not flying by itself into the Flight Plan folder.  You have to create the ".txt" route with SimBrief, Online Flight Planner or any other program and copy it to the A330 or/and X-Life "Dlight Plans" folder.....
3 If X-Life works (I got for LFPG an error message) then instal route with it. If not write your route "LFPGKJFK" on FMCU into co route.....
50 (edited by Cbrchrille 2017-02-02 13:03:22)
Re: X-Life ver 1.2
Stupid question, where do I download 1.2rc2?
Edit: I solved it
