251
Re: X-Life ver 1.1 (r1, ++)
Test Flight: LGMK- LTFJ, A320neo 2.6r2, XL 1.1r3, X-Plane 1.45r2, iMac27 Mavericks
ROUTING:
ROUTE ID: DEFRTE
LGMK/34 LETS1D LETSO R32 ERIMA UR32 IMR UG80 BIG UY146 TURKO TURK1G
LTFJ/06
No crash -XL perfect coordinated with OnlineFlightPlanner and Simbrief
LGMK: Middle airport with low traffic frequency
LTFJ: Big airport, well designed but totally lucked of roads and car traffic to and from the airport!
Sprightly aircraft air and ground traffic on taxiways.
Note for JAR: During takeoff and descent there are almost no other aircraft in front or behind. In earlier versions other aircraft occurred more often in front or behind which caused evasive maneuver or a go-around. These events are missing completely in the current version.
Curious to hear what do you have for us in your XL bag.....
252
Hi Eugeny,
problem with LIEE.
Why does LIEE not work. It always say "Please turn on traffic before", but traffic is on (see pic).
Whats going wrong
please give a hint.
greetings Mike
ps. i cannot change gates and radios and so on, because "traffic is not on"
253 (edited by magicmandi 2016-07-04 22:51:16)
Hi Guys,
first of all i wanna thank you for that awesome plugin.
When i turn on the traffic, i have strange green light over my airports?! Is there a way to turn them off or something like that?
thx in advance
http://jardesign.org/forum/img/m/2859/t/p1ams1kc57lpbniu1na81tl9h4s3.png
254
magicmandi wrote:
Hi Guys,
thx in advance
It has nothing to do with X-Life. It is probably your RTH adjustment
255
Sure it has something to do with xlife. Because when i turn off xlife, the lights are not there anymore.
256
How a bout a log txt Please.
Happy Flying,
Hi, I am trying to load a flight plan from the A320neo FMS ( plan made with "online Flight Planner") into XL using the "Load from FMS" option, but it says "Aircraft not Supported". It says the same with the A330. Please Help.
John.
258
Happy Flying,
Where can i find the log file?
259
There is an other example. the lights are not near the plane, they are just somewhere on the airport.
http://jardesign.org/forum/img/m/2859/t/p1an00hhcf1bb11vq31bpahff103v3.png
260
Happy Flying,
Magicmandi,
The log is located in the X-Plane folder between the Data and Metar files.  When you attach this file to your post it will be identified as log.txt.
Ron West
261
Watauga wrote:
Happy Flying,
Magicmandi,
Ron West
Yes thank-you it is exactly what we need and you attach by clicking the "attach file" button after you have posted the post it will display the "choose file" button. So, you can attach the files.
Happy Flying,
hi to everyone,
does anybody knows what about eugeny (jar)?
no posts, no new beta release, no news, no feedbacks, ...
greetings Mike
263 (edited by ilankrt 2016-07-07 17:10:23)
Test flight URSS - URRR XL, A320, FM last version and X-Plane 10.50b5 !
First time using 10.5b5 on test flight without any problem
ATC - concerning bot airport sceneries - missing alternative RWY suggestion!
A320 - XP 10.50 enable wind aloft, so now it causes some "noise" in cockpit
URSS and URRR very nice sceneries and good functioning air and ground traffic. I wish only that the parking number will be more clear to read from cockpit.
BTW: I am missing since a long time other test flights instead of complains....
264
hi to everyone,
greetings Mike
They are focusing on getting the A320 and A330 ready for 10.50.  There was a new release of the A330 yesterday.
265
hi , I'm sorry, but I need help.
I have a license deluxe X-Life. Not open me window Flight plan. Window ATC no problem , Window Flight plan problem. I do not know what to do to x-life work again . Thanks you .
Lubomir Zouhar
266
Lubomir Zouhar
What is your departure airport?
267 (edited by captbullett 2016-07-09 14:32:37)
Acei wrote:
hi to everyone,
greetings Mike
Ok enough speculating JAR is a pre-Beta tester for X-Plane and is more likely than not testing the "10.50b6 pre-bata and it is now released :-)"
So now he also is getting the JAR software ready for 10.50 put the two items together and the man is busy and Acei you were the one that had the right Ideal so this is just where I posted this and in no way am I saying that you were wrong in-fact you have the right ideal also the man is a family man and it's the first summer for JAR and the baby to go out in the summer and have fun in the sun ... Thank-you for the post.
Happy Flying,
268 (edited by captbullett 2016-07-09 14:46:23)
Lubomir Zouhar
1) Ok in the departure airport put in your airport you are leaving from.
2) The arrival airport put in the airport that you want to go to.
3) alternate airport put in the airport you are arriving at (this is to keep it simple for now)
4) The FL(Flight level) pick one that will work if you see an error message raise or lower the FL by 1M feet.
5) once you have set-up the FP send it to ATC and get you ATIC data etc wind speed,direction, QnH,
6) Call for ground for start-up and taxi after sending you flight plan to ATC.
this is the basic way to use the X-Life plugin you can get more advanced once you learn the details of the plugin...
Happy flying,
Lubomir Zouhar
Happy flying,
Apparently, there was a bad translation.
when I click : (Menu ) Plugins / X-lixe / Flightplan , the window flight plan with does not appear. The window flight plan at all does not start.
270
Lubomir Zouhar
Happy flying,
got it if you are on windows C++ and Oh, I can't think of the other up-date you need from MicroSoft for the boxes to work but I think you get what I am saying there are up-dates you need from MS...
What freezes  the beta tester community?!
272
Maybe, there is no new beta available and the "old" issues aren't corrected
development is temporially "shut down"
273 (edited by captbullett 2016-07-11 20:44:09)
Good Day,
good news Beta testers I want to thank all the testers for making the X-Life plugin such a great plugin and even though you don't see anything going on I can tell you there is alway things going on here and at X-Plane.
Happy Flying,
Angelique van Campen
Jul 10 (1 day ago)
to me
Hi Brian,
Just to let you know that I’ve started with an impression of X-Life. Once the impression is finished (doing right now two reviews together of which the other one if the PMDG DC-6) I let you know, Ok?
Brian Helip
1:42 PM (0 minutes ago)
to Angelique
Thank-you so much for the follow up reply the PMDG-6 is also a great addition to the X-Plane world.
Happy Flying,
Based on a recent flight to an airport that I had added an ILS and associated STAR, X-Life ignored the ILS and directed me to the standard (default) RNAV approach. I get the feeling that X-Life is not using the Custom Data folder like the A320/A330 does. Is that right and if so, should it not use the same algorithm that the aircraft does so that ATC instructions match what the FMS allows me to select?
Cheers Mike
275 (edited by laohu314 2016-07-16 00:47:16)
A rare CTD with the A330 on push-back at KBOS
iMac 27” (late 2015), Core i7, OSX 10.11.5, 32GB RAM, AMD Radeon R9 M395X 4096 MB VRAM
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP v10.50b6, JD A330 v1.3r2, XL v1.1r3, FM v2.4r1, SMP3, RWC, FWL, PythonInterface, Xchecklist
