601 (edited by captbullett 2016-05-22 17:09:04)
For starters, I hope everyone is having a good day, as I am have a good day and just ran a simulation from KMIA/TNCM
this is one of the cool route to fly in X-Plane as it takes some skill to land at TNCM compared to, landing at KMIA.
Moreover, vatech has been working on converting the scenery over to X-Life scenery and we need to give him a big thank-you for the work that he is doing in that department making the scenery work very well and helping with the Bluebell library I like the work that was done on that file also.
For the most part, this post is to give the log txt and bbox so jAR can test the route as I ran into a rout issue with the one runway and the 'Old scenery' issues again the ATC was calling for runway 28 yet, the only runway listed on the MCDU was runway 10.
the flight went very well even with the wrong runway ATC called for as I was able to land on runway 10 without issue. since the MCDU was programed for RW10 and i had no other Runway to pick from.
so here is the data;
602 (edited by captbullett 2016-05-23 05:14:50)
Good day
another airport that the runways are not right this is on the A320 Ne so now I will try the A330 and see if it is just the A320Ne or a system wide issue. and is it X-Life or just the JAR aircraft or Navagraph data .
Update Note Monday 01:13 Hrs
This is an ATC issue it is only giving a Runway 03 for the only runway to land "."  and the JPG will show that this is on all the airports in x-life I do not know if this is just on my computer or, if anyone else is going through this ...
Attachment icon Screen Shot 2016-05-22 at 10.36.51 PM.jpg 78.48 kb, 142 downloads since 2016-05-23
603 (edited by laohu314 2016-05-23 01:26:43)
Reporting similar CTD as ilankrt at KJFK preparing to depart for KBOS
iMac 27” (late 2015), Core i7, OSX 10.11.4, 32GB RAM, AMD Radeon R9 M395X 4096 MB
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, lAR A220neo (latest beta), XL 1.1b7
604
I filed a flight from KSEA to CYVR using X-Life 1.1b7.  The only tab in the ATC that responded was ATIS.  I could not get the delivery tab or ground tab to function.
605
Flight from LFMN to LFBO.  No CTD.  However, the ATC panel in X-Life is not responding to anything except the ATIS tab.  When selecting the Delivery tab no message is received.  There is a message in the upper margin of the ATC box.  See attached pictures for both the delivery tab and ground tab.
The only response I received from X-Life ATC was my speed being over 250 knots (see third image).
606
Hello, flight from KLAS to KDEN. All went well until final approach: no handover to tower issued. Log etc attached.
Maybe handover is triggered at a specific altitude instead of distance to runway? Apt Elev KDEN 5300ft.
First time, I noticed this on XLife - but never flew to DEN before with X-Life.
Thanks for this awesome work, Jar!
Attachment icon settings.txt 165 b, 236 downloads since 2016-05-23
607 (edited by laohu314 2016-05-23 15:34:53)
Disappointed. Another CTD at KJFK in the A220neo. Will try this in the A330 now.
Also, as reported before, constant ATIS announcements which get really annoying...
608 (edited by captbullett 2016-05-23 19:06:29)
The announcements will stop when the QnH is set to the right setting, at lest that's what happened for me.
Yet the ATIS is very Bad just going on and on and on and on and on and on and on and on and on and on and on and on and on and on you get the picture while you are trying to make adjustments while landing.
So, It Must be fixed ! I just don't  use it for now.
Nevertheless, this is why I keep asking for all log txt no matter how little the issue you never know what need to be looked at.
ATIS played (nonstop) by X-Plane or by X-Life?
610
Completed KJFK to KBOS with minor route problems but no CTD in the A330
Now trying KBOS to KJFK in the A320neo
Will see what gives...
611 (edited by captbullett 2016-05-23 19:05:37)
X-Life then it stops when the qnh is set and it is only with the a320ne
612 (edited by laohu314 2016-05-23 20:53:44)
Actually, KBOS to KJFK completed without problems flying the latest A220neo. ATC asked me for a GA (as when I flew the A330 from KJFK to KBOS) which I duly ignored and landed anyway. FM car didn't start automatically so I had to call up the FM car map to get to a gate (again without problems).
There seems to be an issue with Navigraph AIRAC cycle 1605 though. Some runway approaches seem to be missing in the FMGS...
613 (edited by captbullett 2016-05-24 00:35:17)
I had a GA which I was able to perform in the A330 at  FL2500 and I used the little blue line that is there for just that reason you should start to try it as it does work you just need practice. and as far as 1605 I do not know if it is 1605 or the latest up date on the JAR aircraft can't tell with everything going on but you might be right ...
614 (edited by ilankrt 2016-05-24 12:45:03)
HI JAR
XL 1.7b
Something with ATC seems not to work as it should  (I wrote already about).
Having every time  a crash while I try to prepare aircraft (A320) under XL.
In addition
1. As I initiating XL, the X-Plane ATIS is activated and I have to activate radio and change channel to stop it.
2. ATC text out of frame
3. Crash after a new ATC frame appears
Stopped testing and Waiting for your next beta....
615
It is X-Plane playing ATIS constantly
616
I rebooted my computer after which the ATC panel tabs were functional.  I tested KSEA and LFMN mentioned in the above two posts, and both worked.   I reviewed the above two log.txts and noticed the line "Flightplan sended to ATC:" was missing.   I either forgot to send the generated flight plan to the ATC or some file was messed up and got corrected when I rebooted my computer.
617 (edited by captbullett 2016-05-24 15:25:14)
Yes, re-booting the computer is the way to fix most of the issues in X-Plane but most people forget this step and only get up-set and start blaming the developer for a bad plugin, just remember there are a lot of one's and zero's that the computer puts in to place as, the binary part of the computer need to be right for X-Life and as, the rest of the computer needs compile to work right.
Thank-you
Happy flying,
Captbullett
618
Just successfully completed KJFK to KBOS in the A320neo. Had a bit of a problem when ATC gave me a VOR approach to rwy09 at KBOS, a procedure that doesn't exist in real life! So, after going around and lining up at the other end (rwy27), I hand landed the bus. A bit of excitement for the PAX but otherwise fun.
619
I also came from KJFK and just landed at KBOS (didn't recognized your A320, maybe because of simulating under real weather conditions (and you?) KBOS was under heavy fog big_smile) But I installed XL 1.6b back again, because of steady crash with 1.7b. During flight with the A320neo I had frame rate drop to 2 fps. Only after refreshing real weather twice frame rate went back to normal.
KBOS has a very busy traffic - that was amazing. FM car work well.
BTW at what flight level did you fly (me FL250, FMC didn't aloud higher alt.)
And I would like also to know if you are using on your new iMac the latest OSX version and if yes how it works with X-PLANE AND JAR Airbus + XL?
620
So you had CTD's and yet you did not post any Log.txt so JAR can debug the version of the X-Life that need to be debuted and you went back to aversion of the x-life that is not current.
This doe nothing to help the beta testing Team in fact it hurts the team and this is why I have my attitude towards you
you do not fallow direction and you do exactly what ever you want to
you are worse than trying to get a three year old to listen!
621 (edited by ThommiTechnik 2016-05-24 17:12:00)
Are you flying Starflight One? wink
622
Completed another successful flight KJFK to KBOS in the A320neo. Don't know what went wrong earlier with the CTDs.
This time got a working approach although I had to do DIR to line up correctly because I had another approach programmed before I got the one from ATC (different STAR, GDM4 instead of ROBUC1)
623 (edited by captbullett 2016-05-24 17:48:22)
JAR A330 and Just using a little brain power by reading the SmartCockpit.com manual ...
and following the directions of the ATC  on the X-Life I made a flick but it was a the wrong FPS so next time I Get a GA I will make another Movie and post it for training ...
624 (edited by captbullett 2016-05-24 17:54:55)
we only need reports when you have a CTD or an issue that needs to be reported not every flight. I had had to correct some Flight plans at time it is not a perfect system but you have to be smart enough to fix it and move on...
but thank-you very much I wish everyone helped like you.
I was reporting these successful flights because ilankrt and I had CTDs at KJFK under the same circumstances which we also reported. So maybe the good people at JAR Design can compare the logs and crash reports to figure out what went wrong.
