551
I have asked for log.txt and bbox.txt so we can help with the issues this is Beta testing and for the new people that have now posted with issues here you must post log.txt and bbox.txt not a request but a must during beta testing this is why you have a 50% discount on the product.
Thank-you
ryangregory00 wrote:
Can someone post their pictures on how their bluebell aircraft library and x life are organized?
yes I will as soon as I get to my other computer I was at the VA today and just getting to my computer .
I will post the screenshot of the file tree.
i fixed the bluebell library and all works well now.
554
Denco wrote:
I would really like to buy this product, but first I have a few question.
1. Does ATC use speech recognition and can I use my IVONA voices for it?
2. Why only TCAS planes for atc. Will we ever get an ATC for all panes? This one is the one that is preventing me from buying it since I mostly fly the 737 200.
I would also like to thank you for the free traffic plugin.
Please really save your 10$ if you care so much.
555
What kind of an answer is that. All I'm asking is why doesn't the atc expand to other planes. Is there some sory of a limitation. I can't see the sense in this design decision.
556
First:
This is the true answer! If you seriously ponder whether you spend $ 10 or not, then this mean - the 10 dollars is too important for you may be. If so, In this case - certainly in your life there are more important things that you really need. For example - the food. Or some other.. I dont know. May be you need just use freeware version. Please think about this and Please do not make mistakes.
Second:
And more, please. When you ask like this:
or this
or this:
Nobody understand you and what did you mean. I am not understand absolutely. Atc work with any user aircraft type. What limitation you talk about? What about TCAS did you mean? Why you talk about TCAS at all? If you prefer not see traffic around you in hard weather - your choice. May be you mean transponder? Yes, it need. But you say nothing about transponder.. May be you mean Flightplan export function for other aircraft? But you say nothing about Flightplan.. Ok, stop. I find it hard to spend a lot of time solving your puzzles. I guess I need to buy a textbook in English, because I have ceased to understand sometimes. I'll be back soon.
557
I was comparing various sceneries on X-Life and noticed that KATL has a higher traffic volume than all of the other airports. Is it a different airport file or something causing this high density? I would like KORD or KMIA to have this much density.
558
Air traffic density depend of airways density (number of ATC-points per km2) and power of user computer. But that picture - is WOW!
559
Is it possible to have the density at Kord like that? I am running i7 4790k @4.5ghz gtx 790. At Katl i have 3 runways departing and landing at the same time. Is that possible at another airport?
560
X-Life take in account not the "runways number" but  "independent runways number". So - crossing runway give you less traffic then parallel runways. I cant answer exact, cause XL is designed in such a way as if it is inside a living organism.
561
I ran into a problem check out the picture
562 (edited by epeder20 2016-05-20 01:19:53)
When I start X-Life the routes are created however no planes taxi to the runway.  I have included the logfile.
I see a lot of errors:
0:04:28.341 E/ATC: CreateTaxiRouteToRunway failed for p1(N01XP) during an initial clearance to 32R
0:04:27.903 D/ATC: Validating altitude for p1(N01XP): filed: 36000 usable_rte_dist: 1034.374756 maxDescent: 258000 maxAlt: 258000 minAlt: 36000 chosen_alt: 36000
0:04:27.903 D/ATC: p1(N01XP): Cleared IFR
0:04:27.903 D/ATC: p1(N01XP): Squawk 4700
0:04:28.085 D/ATC: Validating altitude for p3(N03XP): filed: 9000 usable_rte_dist: 128.199829 maxDescent: 32000 maxAlt: 33000 minAlt: 9000 chosen_alt: 9000
0:04:28.085 D/ATC: p3(N03XP): Cleared IFR
563 (edited by captbullett 2016-05-20 04:18:44)
0:03:10.308 E/SYS: +-------------------------------------------------------------------------------
0:03:10.308 E/SYS: | There was a problem loading the scenery package:
0:03:10.308 E/SYS: | Custom Scenery/KORD-Chicago-HD-Nimbus Simulation/
0:03:10.308 E/SYS: | The scenery may not look correct.
0:03:10.308 E/SYS: | Please see the log.txt file for detailed error information.
0:03:10.308 E/SYS: | (io_dsf.cpp:694)
So this can be fixed go to the place webpage where, you downloaded the scenery and check which libraries you need and make sure you have everything for this airport ;
Failed to find resource 'test/AGtrees_test.for', referenced from file 'Resources/default scenery/airport scenery/Modern_Airports/Control_Towers/'.
then you were cleared so all you needed to do was call Ground and get clearance to Start and pushback...
and you would be on your way...
Hello JAR, on your BETA version that was just released yesterday, when you install it, and register it, the side bar menu (with green icons) on the right side of the screen has dissapeared, is this intentionaly or is it a glitch?  thanks
565
by testing with x-life, I realized that every xlife session
aircraft with the same delivered to the same location in the sky also are always the same. (The day after turning off my PC sequencing has not changed.)
Should at each session the selection planes is done randomly.
566
You use ver 1.0
Please update it to more fresh version (check first post please)
567
please update your plugin to beta 7
568
You can call it from Main X-Plane menu / Plugins / ..
569
Should be random.
570
oops, this is by moving the cursor to "air traffic density" I found my solution.
cursor which I had not touched.
Another thing, when the aircraft (AI) are too long or too short landings,
I change the length of the track as far as possible. is this the solution?
if you use bluebell pack, you can tune landing and takeoff run length (meters) for every aircraft, but what aircraft have wrong parameters, please?
572
Yes, I have already changed some settings had "bluebell".
What I speak of is the point touched wheels as if the plane landed too long,
it may abut end of the runway and ... bug! ..
El lengthening one end of the track "xlife" I partially corrects the problem.
Then of course, if we change the txt file of the plane, landing a  B777 few 1000 meters but it is not very realistic.
573
Hi Guys,
I have a question:
How does X-Life decide which airport to populate? Of course it creates traffic at my current position. But what does it take to have it automatically create traffic on other airports? Is it enough to file a flightplan to get traffic at my destination? Or do i have to actually follow ATC to achieve that? And what is with the airports en route? Like if i pass a very big airport right after takeoff, is there a way to get that one populated too?
Cheers
Chris
574 (edited by captbullett 2016-05-20 15:02:54)
MasterTRL wrote:
Hi Guys,
I have a question:
Cheers
Chris
this is the list of X-Life ready airports;
https://www.google.com/maps/d/viewer?mi … tAA_7MfME4
this is the everything else in production and is not yet on the map;
http://jardesign.org/forum/viewforum.php?id=33
575 (edited by lanmancz 2016-05-20 15:57:48)
I can confirm IVONA voices work (which is great). I'm using IVONA's Sally and I'm pretty happy with it. X-Life seems to use the default TTS engine you have selected in Windows so when you have selected IVONA it will use that instead of the awful default Anna voice. Great thing is that IVONA actually properly pronounces the airport names and so on and does not spell it out letter by letter like Anna.
