226
Successful flight KBOS-KEWR.
Traffic perfect on both airports.
FPLN had no SID (for RWY33L) and the FM car got lost on the way to RWY33L at KBOS (I guess I need to refine the Taxi Routes even more, although I am a bit at a loss how).
I was given ILS on RWY29 at KEWR again, even though there is no ILS for RWY29. I programmed RWY22L into the FMC and landed perfectly. ATC stayed with me. I didn't request a FM car but selected the prescribed gate on the map and got there, only to find an aircraft parked there.
All in all a great flight.
X-Life rocks!
227
I fly a lot across Spain with Vueling Airlines.
Would it be possible to add one or two "official"' Xlife airports ?
For example Madrid and Barcelona ? (LEMD and LEBL)
Thanks a lot in advance
228
cmckjodi wrote:
Hi so just trying to understand X Life a little better. Ok so as of now a " Verified airport" is one that is on the airport map page and X life will load it's own traffic to those airports when the program is started. So how does one use an airport that is Not verified? For instance I loaded an airport that I made ATC routes for that checked out ok in WED, the planes appeared but there was no traffic movement. Is X-life very strict how taxi routes are created? Perhaps my pushbacks from gates were not created properly for X- life to use? I'm just not sure. Also when I tried to file a flight plan X life would not allow the un verified airport. Seems as like there are some limitations to X life or it's more about me not knowing more about the program which is probably more to the point. Is there a user manual available? That is something that's really needed here. Any advice from experienced users is welcome!
Unverified airports work just fine if the ATC Taxi Routes are well done!
The Ramp-ATC Route connections and the Route-Runway connections are the most critical. Follow the rules IN DETAIL!
You will get it to work. It took me a long time but KBOS traffic and ATC is now working perfectly (except that the FM car is sometimes doing strange things - I need to refine the routes even more) and it's not on the verified list.
Yes thanks finally figured that out after looking at the video on this forum a couple of times. I have KBWI up and running. Now I have to edit a bunch of airports! Will have to try that KBOS KEWR flight.
229 (edited by cmckjodi 2016-04-21 23:36:20)
Does X Life use any type of an air traffic database? Just seems like the large international airports do not have enough traffic. If a plane takes off or lands every minute at a busy airport that would be 60 flights per hour or 1,440 flights per day provided that interval remained constant for 24 hours. 60 x 24 hrs. That number could doubled with airports using multiple runways for DEP and ARR. My sliders are set to max for traffic density and gate activity and runway use set the lowest 2 min. The DEP traffic is reasonable but there is hardly any ARRIVING traffic. I would think a busy airport like KJFK would easily do 1,500 flights per day maybe more. Sure one's computer specs would limit the amount of traffic it could handle. I know things are very much in development here and will take time. Hoping that a realistic Flight schedule database will be made in the future. That would make X life the best!
230 (edited by captbullett 2016-04-20 18:16:15)
pic wrote:
bujablaster wrote:
pic wrote:
Hi..yes, remove WT plugin. And yes, XL will crash if you use an airport not in XL. (it does for me too)
That's strange. My XP never crashed when i tried to activate it on airport without ATC routes data. It simply didn't turn on any traffic, but definitely not crashing (same behavior with last beta versions and actual RC 1.01r of XL). It must be some another plugin interfering with XL.
Well, that was with a way earlier beta. I just stopped using airports not in the data base all the way to this latest release (habits hard to break!)..soooo, since everyone is saying it works, I'll start loosening up on that! Good to know..thanks a bunch!
Yup, I was shut down for about a month turned on the computer made the up-dates needed started X-Plane and up-dated X-Life then did a flight that worked just as it should. I could see the improvements better since, I was away from the testing for a while.
Way to go team, and yes you should use the airports that are approved and tested for X-Life then you know JAR has made sure they work right, otherwise you might run into issue and must expect them and we will try to help when we can.
Thank-you to everyone that keeps making the X-Life plugin better and it takes the team!
Ver 1.1 beta 3 posted. Try to fix some kinds of CTDs, improve radio freq digits pronounce, back a319-320 and 737 to traffic.
Thanks for all your comments! Will continue..
232
not geting a good download on this version on a mac
B.
233
I was using a verified airport KJFK and after a while the ground traffic just quit moving. No DEP or ARR anyone else have that issue?
234 (edited by laohu314 2016-04-20 22:56:25)
Great flight from KBOS to EWR.
Just a few things:
1) I had a plane stuck in front of me which was apparently waiting for me. Did not move for a few minutes so I passed through it.
http://jardesign.org/forum/img/m/1944/t/p1agqtui1560ut6t4i41ttu1lkk3.png
2) The FM car veered off track in the middle of taxiing and stopped so I just continued without it.
http://jardesign.org/forum/img/m/1944/t/p1agqu54i9147b1ps01cja8gpcog3.png
http://jardesign.org/forum/img/m/1944/t/p1agqu0o2foqg1f094ue0s1ih7c.png
Otherwise perfect! This time, I again reported vacating the runway too early but no CTD and no problem when I moved on and reported again!
EXCELLENT!
235
B.
Same here. .zip file has a problem and will not unzip
236 (edited by captbullett 2016-04-21 00:05:32)
B.
thank-you for letting me know it is not just me and just keep using the good version ...
until JAR can fix the issue.
Thank-you,
237 (edited by pic 2016-04-21 04:35:52)
Good Day,
After, a long time off I am just getting back to my computer to run testing after a trip to the ER sent me to surgery and then out to Cali for an extended session on using VB on a Mac. Yet, I was able to keep up with the project so, lets see how good the X-Life project has become. And thank-you for the Team of Beta testers that has worked so hard on the project.
Hope ya feeling better Captbullet! Here's to a perfect recovery!! cool
238
Sorry, ZIP seems like was broken. Just reupload it. Please use!
239 (edited by ilankrt 2016-04-21 17:26:59)
Test flight LICC-LGAV
JAR A320 2.6.1
X-life 1.1b2
SMP Latest + RWC
FM car
on my iMac27 OSX 10.9.5
No crash
LICC: great airport, busy air and ground traffic. FM car working well
LGAV: Nice airport, traffic OK, but
just before landing another AI aircraft on hold short stays green and entering runway
http://jardesign.org/forum/img/m/1591/t/p1agsb52us1ijuc2fbreb4b13e33.jpg
Calling FM car it appears far away from taxi way
http://jardesign.org/forum/img/m/1591/t/p1agsb7s2bo2buf8u2q1h4d5d47.jpg
I wonder how and why XL is programmed to advice nearly every time parking lots that are outside of terminals !?
http://jardesign.org/forum/img/m/1591/t/p1agsbb52ho401n6eb8qe40cna.jpg
Question to JAR: reporting such occurrences, du you need also the log.txt?  Are images useful for you?
Addition: Using XL v.1.1b3.  I made a second test flight LICC/LGAV because of recording failure. this time I looked for a while on the LGAV scenery and traffic. It turned out that taxiways are not marked properly or that aircraft are moving off these ways. Airplanes take-off also do not take place on the runways but beside them on the sand strip. Landings however happen correct almost in the middle of the runways.
Another important observation: take-off of bigger AI airliner seems to show double  aircraft simultaneously !!!
I am preparing a video about LX, ATC, traffic, take-off, Approach and landing, FM car. XL v.1.1b3
240
What does selected aircraft mean at the top of the X Life settings panel and what do you use this for? Thanks
241
Yep, but I am still have not idea where I can get list of european "centers" as example.
Arrival/Departure - yes - a future task
If you want, I'll create a list in the next days?! Will take some days, to create.
Cheers, Thomas
242
Vantskruv wrote:
I do not think it is impossible, if you get help from the community, and develop tools for this, it will work.
First step is to have a major system for centers, which you can build and fragment on. It is up to Romanov which level to start on. Let us say he starts from a state of 1 (which in this example is number 1), and the other states may be filled in by users, almost in the same way as airports are updated at the current state:
State 1. One center for whole of the world with a default frequency, stretching from GND to UNLIMITED altitude.
State 2. One center for every country, defined by a polygon, and with a custom lower and upper limit.
State 3. Segments of centers in a country, with custom lower and upper limits.
(State 4. TMA <- approach, departure, radar)
(State 5. CTR <- tower)
NOTE: airspaces may overlap in a a 2D view, but they should not overlap in 3D space (i.e. airspaces may have the same polygon and position, but at different lower and upper limits, not intersecting each other; TWR below TMA, TMA below CENTER, CENTER below another CENTER and so on).
If there is no state 5 airspace at the position of aircraft, use state 4 airspace, if there is no state 4 airspace, use state 3 airspace, and so on until default state 1 airspace. Of course we could simulate uncontrolled airspace, so we need to be able to setup rules if an aircraft is i.e. below the altitude/flightlevel of a state 2, 3, 4 or 5 airspace. This is only possible if any of this airspaces is defined.
State 2 and 3 airspaces (centers in this case, needs to manually made my the community). The state 4 and 5 airspaces (TMA and CTR) can be retrieved from www.openaip.net, and covers most of Europe and North America.
The requirements for everything to work is to:
1. Make the plugin able to read the data from openaip format (which is open  and easy to parse I think). Also the plugin needs to combine this data with user set of frequencies for TMA and CTR:s.
Because it seems openaip does not support frequencies (I guess), X-Life may modify the openaip data for its own best by just adding a slot for frequency, or pair an openaip file with its own frequency file.
2. A tool for the community which can load and save openaip data, where users may
* read TMA, CTR and CENTER airspaces graphically
* edit TMA and CTR airspace frequencies
* edit/create CENTER airspaces as polygons, and set its frequencies and lower and upper limits.
* maybe able to also create TMA and CTR airspaces with polygons if the area is not covered by openaip
As an alternative to option 1, is to make everything out from scratch and X-Life using its own format.
An important note here, some manually action is required here to align the borders of centers between FIR:s, i.e. let us say user A creates a CENTER airspace for Sweden FIR, while user B is using creates a CENTER airspace for Norway, the border between these two FIR:s needs to be aligned with each other.
Like this idea. We can simplify it, and still have a real effect. I think, at first we should go to airliners. This is in Europe and the rest of the world more easy, because these zones are clear. Once, XL is stable, we (Romanov wink ) could work on VFR rules. Here is the work.
Cheers
Thank-you,
Will try
Cheers
Yes, this is a good Ideal and I would like to see it started at some point in time.
Thank-you for the data and the detail in the report let's see where we can go with this.
245 (edited by laohu314 2016-04-21 22:36:01)
CTD on descent to FINAL (KEWR-KBOS). No idea what happened. Everything was fine, except that even though I was given rwy29 for departure, the FM car I ordered through XL was taking me to rwy11 (wrong end). I must check that the ATC Taxi Route names etc are OK (I did make changes recently).
I then asked through FMcar and specified rwy29 and the FMcar took me there no problem.
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, JAR A320neo 2.6.1, XL 1.1b3
246 (edited by cmckjodi 2016-04-21 23:51:45)
JAR A320 2.6.1
X-life 1.1b2
SMP Latest + RWC
FM car
No crash
Have experienced that as well planes taking off to the side of a runway. And I have had planes land and take off into each other. Now that's a problem! You know nothing is perfect and there's still so much to be figured out with X plane and ATC traffic programs. Hats off to all the folks trying to make a better flying experience for all of us putting so many hours of effort. Things only get better with experimentation. The feedback and strong support will make this a better product. I really like this better than World Traffic so far.
247 (edited by cmckjodi 2016-04-22 00:26:11)
Did my first ATC flight with X-life KSFO to my customized KSAN. All was easy to set up and file a flight plan. My question here is can you file both IFR and VFR plans? And does ATC give you IFR/ILS vectors? I have to try entering a plan into the FMC. Didn't do that on this flight. Also is the ATC system aware of the terrain as you depart and approach airports? Today I was cleared to descend to 2,000ft into KSAN to RNWY 27. The ATC gave me discretion to descend so that was more like flying VFR I have charts so ok. The approach into KSAN is surrounded by small mountains, but the visibility was not an issue. Once on the ground I was given info to the gate. Traffic was adequate at both airports, but feel like it could be busier. These are major airports. Had sliders up all the way for density and gate activity. ATC was not strict about speed at all nor was any speed info given on final approach. That's ok most of us know not to exceed 250knts below 10,000 ft, but certainly speed info adds to the realism. If anyone has info about ILS and VFR flight plans using X-life ATC let me know. Overall I was happy with the experience. I'm sure more improvements will come in time!
248 (edited by Watauga 2016-04-22 01:12:48)
Flight from KATL to KRIC last night.
I was cleared for ILS rwy 20 at KRIC.  Per airport charts rwy 20 at KRIC does not have ILS.
249 (edited by captbullett 2016-04-22 02:30:01)
Good Day,
just up-dated to the latest version and flew a route from KPHX/KSFO great flight all worked well until I went to leave the runway and the Gismo got stuck on having me clear the runway now, I have to change computers to post the log.txt and xbox.txt so please give me a min. or two to post the data. since, the computer is sleeping right now.
This was a very good flight and the flow of the traffic was very good so, I want to keep testing on this version, I just started running the computer after a month sleep.
250 (edited by captbullett 2016-04-22 03:58:21)
Vantskruv wrote:
Vantskruv wrote:
I think it is quite complicated, as countries my have different rules. Let me give you an example (notice I am not a real pilot, but this is my understanding).
The demand to map and  implement "centers" into XL ATC is nonsense.
Such a "project" in the real is "Eurocontrol". Its complexity is far beyond any idea to simulate such a net, not to speak about implementing it in a software like XL.
http://jardesign.org/forum/img/m/1591/t/p1aglqbg8udr71sh3j2n9n62dm7.jpg
What can be done is to take for example the division of european air space into 'CENTER' zones. and for each zone to set a specific FL... not more. Sim pilots under XL can then get advices after changing zones to dial the corresponding zones  frequencies.
http://jardesign.org/forum/img/m/1591/t/p1aglq5va715j89iqfb5102214kf3.jpg
So, I just signed up for the data on the sight that you provided.
now to look into how to implement it into something useful,
I could use some navigational tips on the website on the dat I need to be looking for.
Ps, the system for pulling the Data out is quite difficult even for me and I will need someone to give me some instructions on the data and how to gleem the right data we need.
The data base is quite complex and one wrong move and we will have a mess before we start so it has to be done in a precise order and one country at a time so let make a list country, city, airport,  or if some one else has a better Ideal I have two ears ...
Thank-you,
B.
And the list needs to be of the X-Life Airports and that will make a starting point to the project easer ...
Note#1 if we are going to pull this off it will take the JAR Beta team to do this ...
