126
marvel_master wrote:
after i installed x-life 1.0, i get a message, that there is a version 1.1. But the
Download Link doesnt work inside x-plane. Where i can find the x-life Version 1.1 ?
Hi..the link is http://jardesign.org/x-life/www/
You may have it already. If not sure just DL again...
If, after downloading and installing you get the message again, it's just the news server letting everyone know its available, so just x it out and enjoy your flight!
Hi Eugeny,
just complete a test flight from LIRF to LFMN, all works like a charm execptfor the departure SID, the delivery not assign any SID.
Do you remember our flight with skype desktop sharing? In that flight i have had the same problem, deliver give the clereance but without SID.
For the rest all works fine
thanks for all
Yes, I remember, BUT seems like this is Navdata issue.. as example -
+We select LIRF RW25 for takeof.
+We find a SID at LIRF.txt proc file - EKLO5R
SID,EKLO5R,25,5
CA,0,248,2,410,0,0,0,0,0,0
DF,RF726,41.79547222,12.21821667,0, ,0.0,0.0,0,0,0,1,210,0,0,1
DF,RF701,41.83262778,12.13183611,2, ,0.0,0.0,2,2800,0,1,240,0,0,1
DF,RF703,41.71315833,12.14123333,0, ,0.0,0.0,2,6000,0,0,0,0,0,0
TF,EKLOS,41.57250000,12.30027778,0, ,0.0,0.0,0,0.00,2,8000,0,0,0,0,0,0
+We take Last SID point and it is EKLOS
+We try to build route to arrival using airways, open ats.txt file and.. and.. and..
THERE is No EKLOS point in the ats.txt That mean what EKLOS point not a part of ANY airroute and it can not be used for routebuilding. OOOOpssss! I am stuck.. ATC too, cause it use my brain logic smile
Clear....it's logic smile
thanks
128 (edited by Gesicht 2016-04-11 08:42:14)
Sometimes I have negativ altitudes for some aircrafts. I think this is happend, if two aircraft are to close on final. Here some screenshots. x-life 1.0 and 1.1; Xplane 10.45
http://jardesign.org/forum/img/m/2300/t/p1ag27niuae9v4vs1ujo1ojjitq3.jpg
http://jardesign.org/forum/img/m/2300/t/p1ag27no1i157qv571a7c1mnujf15.jpg
http://jardesign.org/forum/img/m/2300/t/p1ag27ntgr1tm6dkrei1o5j3jc7.jpg
Greetings!
129 (edited by Metallist 2016-04-11 09:39:28)
Good day.
Fly on the route ULLI-EETN on the A330. The entire flight without any problems, the plugin worked correctly, except for two moments.
1. The instruction ATC: AFL1342, Descend to 2200 feet, QNH 1024, transition level FL 50. But to NOAA_Weather METAR, METAR in the A330 and the summary ATIS QNH1025.
2. Parking lot plug-C_8 determined, but Parking for this type of aircraft "A". The screenshot is attached.
And another question. When you select the position control, the frequency to be transferred on the radio panel of the aircraft, and if the frequency of the wind on radiopanel in the plugin it is not broadcast. This is a mistake? Or will this be implemented in future versions of the plugin?
Добрый день.
Полет по маршруту ULLI-EETN  на А330. Весь полет без проблем, плагин отработал правильно, за исключением двух моментов.
1. Указание ATC: AFL1342, Descend to 2200 feet, QNH 1024, transition level FL 50. Но в METAR NOAA Weather, METAR в А330 и в сводке ATIS QNH1025.
2. Стоянку плагин определил C_8, но эта стоянка для типа самолетов "А". Скрин прилагаю.
И еще вопрос. При выборе позиции контроля, частота переноситься на радио панель самолета, а если частоту накручиваешь на радиопанели то в плагин она не транслируется. Это ошибка? Или это будет реализовано в последующих версиях плагина?
http://jardesign.org/forum/img/m/2023/t/p1ag28bfac1408eessbt1dbf1emk3.png
130
Permanent link to actual beta
http://www.jardesign.org/x-life/download/xlifeb.zip
Metallist wrote:
Good day.
Добрый день.
To understand what a reason to wrong Gate selection I will use debug message to beta 1.1b2 like "ATC cant find free gate for user Aircraft. Will use Gate 0 - ..." Please post log if this will happen again.
Но скорее всего АТС не смогла найти подходящую и свободную стоянку для этой категории самолета (плагин анализирует размах крыльев, сопоставляет с категориями стоянок и пытается найти подходящую) и выдало стоянку с индексом 0 (самая первая в списке стоянка). Я подумаю, наверное правильнее - подставлять не 0-ю стоянку а с максимальной категорией по размаху крыльев. Попробуем в следующей бете.
1024 and 1025 it is ok, cause ATC try to get physics baro too.
132 (edited by laohu314 2016-04-11 16:03:51)
CTDs getting quite frequent now. smile
Holding short at KBOS RW15L
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, JAR A320neo 2.6.1, XL 1.1b1
133
Good day.
Добрый день.
Может быть на стадии первоначального формирования траффика в аэропорту назначения (как я понял, это где-то за 60 миль) "бронировать" место для самолета пользователя в зависимости от размеров? То есть, если я лечу на А330, а в порту только одна стоянка категории D, то ее однозначно никому не отдавать и беречь для меня.
134
dvshka wrote:
Good day.
Добрый день.
да, я подумаю над таким вариантом
135
May be a real reason - KBOS. What .dat and .txt you use?
136 (edited by ilankrt 2016-04-11 21:08:15)
Test flight EDDL - EDDN
X-Plane 10.45
X-Life 1.1b1
A320neo
iMac27
No crash
During approach to EDDN another aircraft was suddenly approaching directly behind my A320 at higher speed. On ND its diamond changed from white to yellow and I got a collision alarm. On the XL radar it came so near that in fact it flew just under me. Then it vanished and I got all-clear signal.
On one hand I experience an exciting scenery. On the other hand the AI aircraft should have to keep a minimum distance to my aircraft and reduce speed (at least not to fly faster then me)
Looking at the log.txt file I found this wired rows :
XL: 2965 : !!! Unknown Check Ai Brake case"
What does it mean?!!!!
137
JAR
Can you please on occasion update the XL airports folder and the airport map......
138 (edited by laohu314 2016-04-11 22:47:40)
CTD after vacating runway at LOWW (arriving from EHAM) - frustrated after a cool flight...
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, JAR A320neo 2.6.1, XL 1.1b2
139 (edited by kick.remi 2016-04-12 07:27:52)
I am not sure but it looks like Life and SkyMaax pro 3.1 can not coexist as I am getting CTD when starting X-Plane with the two in my plugin folder.
140 (edited by Wangenheim 2016-04-12 09:16:46)
X-Life 1.1b2
A320neo + BSS 2.0
Win 8.1 x64
Got CTD (x2) at UMMS, when AI plane reaches the runway start point.
Good day. Flight on a route UMMS-ULLI on the A330. Flight without any problems.
142
Howdy! Great flight.
Windows 7
LIRF-LFMN
JAR A320 2.6.1
X-life latest
SMP Latest
FM car, GrndHandling
Smooth, no problems. Only that ATC Instructed me to ILS 21R  in NICE...there is no ILS 21 L or R, only 4L and R have ILS.
Beautiful Plugin. Love seeing a plane nearby at FL250 both on radar, map and warnings.
All I can say is, X-Life, get em while they're hot!!!
143
Hi guys,
I'm having two issues and they only appeared with the last few updates. I use XLD to create a flight plan from 2 xlife airports. XLD creates the flight plan but repeats way points throughout the plan making what should be a 1600NM trip into 20000NM (albeit with correct waypoints etc, just repeated over and over).
I can't figure out what's causing it. The only thing I've done recently is update the AIRAC to 1604. The FMC in both the A320 and A330 show this correctly and I have no issues creating, saving then importing my own flight plans from Rfinder for example. The issue seems to lie with XLife and the way it's creating the flightplans.
I can also save flight plans from Rfinder in the Xlife flightplans folder and import them.
Another issue that came to light today is that the XLD flight planner will now not export data to the FMC?
Any ideas?
Thanks, Ben.
144
Not sure what to do..I have FM Car on screen....World Traffic iniatilizing..but screen locked up..can't get to menu at top. Is a plugin colliding with another. No log txt in xplane10 to tell.. I did update the xpl files in X-Life. Not sure that did it?  Any help appreciated.  Mouse won't go on top of screen..only behind.
Thank you,
Bob Morehead
145
I use these:
http://jardesign.org/forum/viewtopic.php?id=1884
146
Thank you,
Bob Morehead
1.Redownload/reinstall X-Life
2.Remove WT
3.Run X-Plane
4.Attach log.txt to post
benjcarter wrote:
Hi guys,
Any ideas?
Thanks, Ben.
Ben Log txt and up-date from the last to AIRAC to 1604 has done something, just do not know what yet, need log..
thank's
How do you guys create the ICAO.txt files for use with x-life, I don't mean what editor BUT where do you get the info from
You can get the necessary information from up-to-date airport charts (e.g. From Navigraph)
150
I don't get what you're trying to say here. I have this problem regularly too. But not 12 mins, more like 20. This has caused me to stop using the plugin entirely, and I paid money for it. It's just not realistic to wait for an aircraft that's 25nm off the runway. Worse is when you do wait and then the aircraft that was landing decides to go around
sad
ThommiTechnik wrote:
Tried the RC1. Really not bad. But:
• is it the plugin, or me, at LSZH and LFPO I was waiting for 12mins. for DEP on HP, because of a landing aircraft in 25km distance! Waste of time and fuel wink Our boss at SWISS would kill all the controllers wink
can you try different settings (in X-Life settings) in the timing of runway time as 1 and 1/2 mins this is the setting I use and if you take to long at the gate starting things it can effect the timing so I would try some more of the same route and with different settings also do a back route to get the computer use to the route.
some of this is trial and error and only you can do the testing on your computer because of the specks on the computer build.
i hope this helps you to understand the nature of how this plugin works its tuned to your computer...
Ps, please keep me posted and I will work with you to get it fine tuned...
