1 (edited by J.A.Romanov 2015-04-24 22:53:51)
Topic: v1.1b2 distributive (Windows 7/8, MAC OS)
beta 2 is next step to determinate MAC OS CTD issues. This time i rebuild C++ sound code to avoid dynamic sound loading. All sounds load only when a330 open. We will se how it is stable on MAC and what kind of crach reports will be (OpenAL or not). Please post your MAC info and CTD reports here. Please discuss this Beta here.
Download link http://jardesign.org/a330/download/inst … v1.1b2.zip
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
But the main reason to publish it - new sound system, what absolutely not use SASL-based sounds. And interesting how is stable/unstable with MAC OS. Please post MAC OS CTD reports here (log.txt, MAC OS crash report)
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
Re: v1.1b2 distributive (Windows 7/8, MAC OS)
ok, lets discuss it here - how it stable, how it work..
3 (edited by rajo 2015-04-24 23:26:08)
Hallo Master JAR,
the second flight ZULS PRO CO SDP VINAD RAJ IS VECC was successful, only confused about flickering engine power meter
nastrowje!
rajo (Alfred Herrmann, Bonn)
X-Plane 10.35r1 (64-bit build 103503), Mac OS X: Version 10.10.3 (Build 14D136)
CPU type: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz CPU speed (mhz): 4000 Bus speed (mhz): 100 RAM (MB): 24576
4 (edited by Kevinh 2015-04-25 21:22:12)
Hi I have purchased the A330 this evening. Is this a later version than that which I downloaded from Xplane org ?
Happy to send you crash reports etc and load new betas. Just a little concerned about repeat activations ?
5 (edited by J.A.Romanov 2015-04-25 21:34:57)
rajo wrote:
Hallo Master JAR,
nastrowje!
Thanks for report! Any reports - very helpful! Sure, need fix flickering.
You get stable copy from shop (v.1.0r2)
If you want, you can install a second copy (this beta) and activate it with your serial with no problem.
MAC
departing LRCK, about 3000ft after start
http://jardesign.org/forum/img/m/367/t/p19jpa4je91jc717fpla313pv1hcq3.png
8 (edited by rajo 2015-04-26 00:10:06)
Hallo Master JAR,
CTO at ramp, see https://www.dropbox.com/sh/qle7olkjc1hw … rdtsa?dl=0
PS: why I m sometimes not able to attach files here? only images?
Attachment icon bbox_log.txt 119 b, 408 downloads since 2015-04-25
rajo wrote:
Hallo Master JAR,
just click "preview reply", then "Durchsuchen..." (Upload) button appears. Seems to be a bug.
MAC
in cruise and close to TOD from LROP to LRCK
specs see posting above
bblli wrote:
rajo wrote:
Hallo Master JAR,
Thanks , I edited the orig post
12 (edited by abc_lilei 2015-04-27 11:02:21)
MAC
Attachment icon X-Plane_2015-04-26-103145_lileideMac-Pro.crash 71.97 kb, 193 downloads since 2015-04-25
Attachment icon X-Plane_2015-04-27-185158_lileideMac-Pro.crash 72 kb, 208 downloads since 2015-04-27
Thanks for the quick response.
I Assembled images at the upper right corner many times, but was not able to choose file (no file Chosen), So again dropbox, same folder: https://www.dropbox.com/sh/22l6jpw6ve8e … ismoa?dl=0
MCA
taxiing for departure london luton
CTD while accelerating on RWY 06R in LEPA
All Crash Reports are in on log
