Topic: v1.1beta1 (Windows 7/8, MAC OS)
v1.1b1 distributive (Windows 7/8, MAC OS)
Download link http://jardesign.org/a330/download/inst … v1.1b1.zip
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
But the main reason to publish it - new sound system, what absolutely not use SASL-based sounds. And interesting how is stable/unstable with MAC OS. Please post MAC OS CTD reports here (log.txt, MAC OS crash report)
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
Re: v1.1beta1 (Windows 7/8, MAC OS)
Flight #4 - CTD on T/O
Flight #5 - CTD on Taxiing
Are we getting ambient cockpit sounds (packs, equipment cooling, etc etc) with this update aswell?
Cheers!
Cheers!
all sounds are the same. only plugins (program code) changed
- Downloaded the v1.1beta1
- Activated the update
- Hot started the aircraft
- Changed the view to 3D ... crash to desktop.
It's really a pity; this machine is getting to be my favorite aircraft ...
Attachment icon bbox_log.txt 122 b, 277 downloads since 2015-04-23
Attachment icon X-Plane_2015-04-23-163525_iMacIVYBridge.crash.zip 16.58 kb, 303 downloads since 2015-04-23
Understand. Thanks for info. Now, I done 1.1b2 - just try another way to load OpenAl samples. Will post of trying soon, I hope - tomorrow. Very interesting problem.
... Very interesting problem? I'm glad you like it ... LOL
He said he finds it interesting. Not that he liked it ^^
Not like the problems, but sure, very interesting to find solution.
True ! Good luck with that ...
I am afraid that without cooperation between developers of SASL it will not be possible to find solution.
12 (edited by FS Steven 2015-04-23 20:13:13)
The problemen is that this whole SASL problemen takes too much time which results in less time for the actual A330 itselfs sad Hope this SASL problem gets fixed asap.
Could Gizmo be used instead of SASL? I read the up-incoming 737 uses Gizmo
Sounds interesting pcartier! The IXEG 737 Classic also indeed chose to go for Gizmo, and not for SASL! Also SkyMaxx is working with it I saw (bought it this week).
