Topic: new balance 998
The collaborative 1700 created by New Balance new balance uk and Japan s Beauty and Youth is seen above, released earlier in the week at premium New Balance accounts worldwide. The low top sneaker is built from the most luxury materials the brand s could buy comprised of beautiful tanned leather and Black suede.The insoles of the 1700 are equally as artistic, with a collage of logos designed by both New Balance and Beauty and Youth. If you want to grab these, check for them now at select New Balance retailers, such as Feature.
The New Balance Numeric gets a pretty special release in conjunction with Miro. The artisinal notebook manufacturer has teamed up with New Balance to release not only a special colorway of the New Balance Numeric Brighton 344 but also a special edition catalog of the skate line. The sneakers features an embroidered New Balance and Miro logo on the side panels and a gum outsole. The spiral bound catalog also features a new balance 574 sale cover with the same material as used on the sneakers upper. Check out a few exclusive images above and let us know what you think of New Balance s latest.
With 2013 in full effect, we have seen a number of Year of the Snake releases, though this new one New Balance has somehow flown new balance 574 uk under the radar. Honoring the Chinese Zodiac, New Balance offers up a few new versions of the New Balance ML574, each one inspired by the snakeing in four different colorways, the low top sneaker is built from a number of premium textiles. The mix of materials play nicely against each other, using scaled textured leather and patent leather to make the design pop. If you want to grab a pair, check for them now at select New Balance retailers, such as Feature LV.
We initially previewed the Beauty Youth x New Balance 1700 back in December, and today we re seeing new images of the sneaker, as well new balance 574 mens as learning more about its availability. The sneaker features black suede and mesh along the upper, while buttery tanned leather is applied to the heel and tongue. All the while, the insole bears the brands name illustrated by a series of street signs provides the perfect finishing touch. The shoe will release in limited quantities on Saturday, January 26 at select New Balance retailers.
If you remember missing out on the atmos x New Balance 996 Face Off then your second shot at glory has finally come around. The collaborative model will see a US release courtesy of UBIQ and while we aren t sure exactly how many pair the retailer will have in stock we do know that it is set to hit their shelves on January 19th. We highly suggest making your way to a pair of these thorough New Balance runners if you are in range.We saw this pair of New Balance 1300 Made in the USA earlier this month, and now we re coming across more images as we see the sneaker make its way to a variety of accounts including New york City-based Kith. Built from suede and mesh, the sneaker trades between charcoal grey, red, and blue. All the while, white works the shoe laces, lining, and sole.
Check out this new collaborative pack from Stone new balance 998 Island and New Balance, dubbed the SI_577 Pack. The two give the 577 a new twist, trading the traditional materials for the best that Stone Island has to offer. Available in two different colorways, the shoe is built from a new material known as RASO GOMMATO, featuring a military grade satin weave cotton that is dye friendly. A mix of polyester and thousands of glass microspheres are used to create the highly reflective material seen on the heel, with a matching rubber N used for the branding. Exclusive to the Italian market, you can find these at Stone Island now.
