76 (edited by captbullett 2017-03-04 05:34:27)
Re: X-Life ver 1.2
Lucy I'm Home ! now I'm on a windows computer right now taking some programming classes and just made honor roll at Santa Monica college.
So, how is every one here? I see there are no log.txt being posted.
Therefore, the aircraft are going to go where ever they want to go.
So, lets start by going back to the basics and give me some log.txt please, and just so you know I have two classes I'm taking right now so any help will be secondary to the college courses for the next ten weeks or so. its good to be back everyone LOL...
Happy flying,
77 (edited by ilankrt 2017-03-04 12:06:18)
Re: X-Life ver 1.2
This shouldn't happened any more!
KJAC Jackson Hole - AI aircraft on taxi way (not correct designed) without control:
http://jardesign.org/forum/img/m/1591/t/p1bacj87pa1u7vut81hr97sn9803.jpg
and at KLAX
http://jardesign.org/forum/img/m/1591/t/p1bacj94rmo421rlfktbgn71g8k7.jpg
AI without stop loop is a main problem on many proved airports...
78 (edited by jamiemail 2017-03-05 10:41:11)
Re: X-Life ver 1.2
Dear JAR.
Can you please tell me when the implementation of DIR routes will be added to X-Life?
I'm currently unabke to submit any route with a DIR or DIRECT command.
This is essentianl when flying low altitude VFR routes off of airways.
Thank You.
Re: X-Life ver 1.2
Hi Jar
I am very sorry but I have to tell about the last approved airpots that:
1. UWOO is an old scenery from 2009 in nowhere land...
2. UWUU and UWWW to download from .ru - I got warning that the files will harm my computer!
3. UWGG for 16$ is not a very distinctively scenery (not worth to pay for) in a boring landscape.
There are many other wonderful made free airport sceneries that JAR simmer has made for them suitable .dat +.txt files to take them into account and fill the airport map....
Re: X-Life ver 1.2
kebs wrote:
Hello
with A330b4  XP11 b9, xlife 1.2  trying to make a flight plan  LFPG/KJFK
when I export it to FMS, total distance 16453 NM
Same FP in Simbrief 3453 NM
Same result when I create a txt file in flight plans/plane folder.
Someone has an idea ?
Osx Sierra
XP 11 b9
A330 b4
Xlife 1.2
Airac 1701
There are no Cross-Atlantic route that I'm aware of yet in XP I will stand corected if there is. And this is why the route does not work as you want it too. (no great circle route)
Re: X-Life ver 1.2
Does anyone know if XL accepts .dat files from WED versions greater than 1.4.1r1 (e.g. 1.5.0b1 or 1.6.0b1)?
many thanks!
Re: X-Life ver 1.2
ive just added a320 cfm sounds and want to know if I installed it correctly and do I have to delet any files on x plane 11 thanks
83 (edited by fjperreault 2017-03-20 00:43:23)
Re: X-Life ver 1.2
The ability to turn off ATC in X-Life Deluxe would be useful for some of use who use other 3rd party plugins for ATC.  I use Pilot2ATC and anytime I take off I get an ATC window from X-Life telling me to set things up for it.  If I could turn off ATC yet keep the other goodies in Deluxe like the Radar and Info windows then that would be great.
Perhaps a new option added to the Setup window?
84 (edited by stolowski 2017-03-28 12:39:13)
Re: X-Life ver 1.2
I've just recently purchased X-Life deluxe and hit the following glitch on my first flight - an AI plane flew above me with another model "attached" to it - so it looked like two planes were one flying object - see attached photo... Looked funny, but also ruined realsim a little bit wink
http://jardesign.org/forum/img/m/4262/t/p1bcaep94g3dj16sjr58hdi18rr3.png
Re: X-Life ver 1.2
Hi to all,
since the last xlife beta version (and maybe some versions below) short flights in europe (eg. distance ca. 300 nm) does not work well, because on short flights you often need DIRECTS and directs don´t work any more in this XL beta versions.
eg. LOWL to LIPZ many DIRECTS: LOWL SID OGRUB DCT DETSA Y106 NIVAS DCT LAREN STAR LIPZ (generated from onflightplanner, but other generator does not work better - AIRAC 1703)
XL is a great product, but now (in the last beta version) i cannot use it.
Does anyone know how to use it which DIRECTS?
86 (edited by SirOTheOne 2017-03-28 16:40:37)
Re: X-Life ver 1.2
LOWW to LIPZ:
generated from simflight LOWW SID UMBIL GRZ RADLY RIFEN M196 BADOP P125 TULIK M859 CHI STAR LIPZ -> flightplan error -> why?
generated from onlineflightplanner: LOWW DCT MOVOS DCT KOGEX DCT RIFEN M196 AKADO DCT LIPZ -> flightplan error -> why?
generated from XL: LOWW SID MAREG L175 XENAK M985 JAN P10 BERVA P10 MAVOR P10 HLV P10 TBV T110 BAVRI T110 BAMTA P31 DEGIN P31 DOSEL M736 MANAL M736 TULSI M736 BERAS M736 MIMVI M736 LIZUM N503 LIKDA N503 BAKOR N503 VESAL N503 LAMPO N503 ROKIB N503 VIC STAR LIPZ -> works, but no airline would fly this route
Re: X-Life ver 1.2
An update on this... I saw another "broken" AI plane in another flight - just wings with missing plane body... Now, that was with default planes from X-Plane, it seems that installing Bluebell XL library resolved these kind of rendering issues. I think that this should either be fixed, or Bluebell library should be marked as required for correct functioning of this plugin.
Re: X-Life ver 1.2
hi jar
I am new to xlife 1.2 I have brought iccarus egcc which is on the map as verified I have traffic but I have aircrafts that would not fly or depart from this airport ie spice jet dash 8 from indian china airways etc how do I get the most up to date traffic at egcc I am using the free version .does the dulux version have traffic between verified airports enroute with atc thanks and your xlife is awesome piece of software can only get better
Re: X-Life ver 1.2
I don't know if it has to do with XP11, but using X-Life:
1. Taxiways are shifted and AI aircrafts are taxiing on Adjacent areas
2. AI aircraft are not positioned correctly.
3. AI aircraft are passing other aircraft not stopping in a certain distance
This all happened for example at LGAV and LFML
If under XP11 coordinate changed, there must be an adaptation. AI aircraft programming must be rechecked.
Very disappointing is that since XP11 ATC FM car call don't function at all on every approved airport.
Re: X-Life ver 1.2
1. & 2. Are you sure you are using the exact same scenery the ATC Routes were made for? I usually see this if I try to use another scenery and then have to adapt ATC Routes.
I have no problem with FM car either with XL or FM using XP11.00rc1 and latest XL, A320
Re: X-Life ver 1.2
Usually I am using the approved airport sceneries (although I have to purchase them). In case of LFML , you are right, I didn't use the recommended version from XPFR (made originally for XP 8). This happens rarely but sceneries like the XPFR one are really not adequate for use with XP11 ! ... I installed FMcar for new but nothing happened ?!!!
Re: X-Life ver 1.2
I've just flown a quick flight with cessna 172 around KSFO. When in the air, I enabled xlife and requested approach vectoring (I didn't run xlife when I started my flight). I got a few sensible vectoring instructions (I was given headings to follow and requested to descend and then maintain 7000 ft). Then suddenly when closing to KSFO I was vectored to SUTRO at heading 287 and asked to climb to 24000 ft?! That doesn't make any sense... even an airliner shouldn't be given such a ludicrous instruction...
Re: X-Life ver 1.2
I have been to EDDH. X-LIFE and Bluebell are installed. But I still can't see Lufthansa aircrafts for example. But many American Aircraft which I have never seen in EDDH. Could anybody tell me the reason for that?
Re: X-Life ver 1.2
Lufthansa strikes !!!!!!!
95
Re: X-Life ver 1.2
I am having the same issue with traffic that does not fly to egcc can someone explain what we have to do to get real up to date traffic ?
96
Re: X-Life ver 1.2
I am trying to fly PHNL to ZSPD using this plan:
PHNL SID PUPPI DCT CRESP DCT 23N70 DCT 24E80 DCT 25E70 DCT 27E63 DCT 28E60 DCT 34E50 DCT SEALS OTR13 KAGIS Y51 INUBO Y16 CHINO Y88 CUE Y28 ISAKY Y60 FUE Y60 ONIKU A593 SADLI A593 DUMET STAR ZSPD
The aircraft loads it fine but X-Life has a problem with
SADLI A593 DUMET
Why is that? All these are in the latest AIRAC waypoint file. I don't know what to change to make it work and prevents me from using X-Life ATC for the flight. Arrrgh
Re: X-Life ver 1.2
Hello, i have some remarks to your product X-Life Deluxe
a) X-Life Settings Panel ... Window Background and Slider are smaller than scale
b) AI ACF Editor : If i Change one aircraft, it changes all currently parking aircrafts. Looks funny if a C172 looks like a A320 or the GAP is filled with A320
c) Plan Editor is not good
- why no copy/paste or at least a paste button
- error Messages are no help to understand why it not accepts a route
d) crossing the way of taxiing (xlife) ai aircrafts sometimes crashes xplane to Desktop .. f.e. if you taxi out of runway same way as ai wants to taxi to runway
X-Life Deluxe
GHD
FMCAR
JD320
Re: X-Life ver 1.2
Disable "Show parked aircrafts" in Xplane graphics Settings if you use x-life traffic
X-Life Deluxe
GHD
FMCAR
JD320
Re: X-Life ver 1.2
How do you have the folders loaded a screen shot of the folder install would be very helpful.
Re: X-Life ver 1.2
How is everyone Hope everone is doing well I have a week of spring break to be on the computer for fun.
hope to here from you.
