I tried this beta version. Few things noticed:
- There is a clickspot to turn on/off screen reflections for PFD, ND, ECAM et cetera. a) it does not save your preference after closing X-Plane, b) this reflection effect is not applied on the MCDU.
- The green effect on the windshield is a bit too odd and too much indeed. However, in the JARDesign Facebook group I posted some pictures about what is possible to make is very very great. X-Craft did it very wonderful. But on the other hand, X-Plane 11 will give this reflection feature as well.
- The cockpit and cabin windows have a too grey tint. As a result: it looks like it is always a foggy day.
- The spoilers after touch-down deploy too fast/too instant. They have to deploy a bit more gradually/smooth.
- There is no intertia involded in the tiller. This inertia is involded in the A330 which is super, but the A320 is missing this. As a result, you are able to perform smooth taxi operations with the A330 and to counter-steer a bit. With the A320, it results to weird and harsh movements.
- After a long period, I also tried the A330 this weekend. The FBW of the A330 is much better than the A320. So, I really hope the FBW of the A330 can be used for the A320.
- Very shortly after airborne, the A320 tends to make a little nose-down effect. This same applies shortly before flaring.
- When I disconnect the autopilot, sometimes the aircraft is going crazy and makes an abrupt nose-up movement.
- The auto throttle system is going crazy when there is (little) turbulence. It is too responsive to every little speed difference due to the turbulence.
- When reaching TOC, the power management is a bit odd. When reaching TOC, thrust is going to idle -> reaching TOC -> applying thrust. This is not correct. When reaching TOC, the thrust just reduces a little and the pitch angle just decreases gradually.
- Same when changing the speed in the FCU. When you change the speed in the FCU, the FADEC makes too abrupt changes. For example: you fly speed 290, want to reduce to 250, hence you dial in 250 and the thrust is going to idle almost instantly and when reaching 250 is applying thrust like we are going to take-off in the air.
This are some points. I hope they make sense and can be taken into account to future update(s)
