526 (edited by Metallist 2016-05-18 19:58:46)
Metallist wrote:
Metallist wrote:
URSS-URRR after permission for taxiing CTD log and dump file
good day
you need to up date and only replace the  .xpl  files ...
Thank you, just now after restart x-plane saw the update. Updated, I will try.))
After update plugin, on the taxi CTD log and dump files.
527 (edited by captbullett 2016-05-18 21:13:46)
Metallist wrote:
Metallist wrote:
good day
Up-date you A330 as it to has been up-dated for X-Life
http://jardesign.org/forum/viewtopic.php?id=1997
Wonderful, perfect, flight from KMCO to KATL in the A330 (latest beta) and XL (latest beta).
At KATL I was watching traffic for a while and had 20 aircraft moving at all times, coming and going without any problems.
XL is really becoming the genius add-on we all believed it would be!
529
Not sure I understand, I have the A330 version 1.3b1
530
Can someone post a picture of how their bluebell aircraft files are supposed to look like in the x life folder.
531 (edited by Metallist 2016-05-18 23:02:43)
The next attempt of the flight and crash again on the taxiing. And moving parallel to the runway ATC asked to hold the position since the runway is busy.
http://jardesign.org/forum/img/m/2023/t/p1aj31hqvsir1qfcna7ddphol3.jpg
532 (edited by ryangregory00 2016-05-19 01:32:41)
how do i get rid of the original x life aircraft?
533
You must hold and the steps are
1) hold and report to ATC that you are Holding.
2) open the radar screen and set to 50NM so you can see the other aircraft around you,
   see what aircraft are taking off and landing on the runway you are about to use.
3) open the ATC widget again if you do not here from TC within a 1-2 minute window but still wait otherwise you will get a CTD because you have broken the string in the ATC programming.
you have to let the X-Life programming work if you do not wait to get cleared you will not go any farther than a CTD.
534 (edited by captbullett 2016-05-19 03:12:53)
Now that you sent the log.txt I can see that you do not have the Bluebell aircraft loaded into you computer right so, you can either send a screenshot of your file-tree and where you put the bluebell aircraft files so we can take a look at them here or you can Skype jAR or you can put a tech support ticket in.
Just not maybe that easy but easy enough to get started to get your bluebell installed.
oh quick question so I can better serve you are you over 18
Download the 3 Bluebell files.
The link is a few pages back on here.
Folders should be like this
?:/X-Plane 10/Custom Data/Bluebell XL/Custom
                                                         /PackA
                                                         /PackB
                                                         /PackG
                                                         /PackJ
                                                         /PackP
536 (edited by Dewald 2016-05-19 07:11:10)
Hi guys
Probably a stupid question.
Can I simply add more Bluebell packs to vary the AI airplanes even more?
Or -- Even add some of the other packs and liveries available on org.
Dewald
537
Metallist wrote:
Metallist wrote:
good day
Thanks! Will check!
538
How_to_install is always include into Bluebell ZIP
Please look at!
539 (edited by Dewald 2016-05-19 08:27:37)
It is not supposed to be in the X-Life folder.
Check 4 posts up.
Please look at!
540 (edited by Metallist 2016-05-19 17:15:19)
I hold and report to ATC. Waited until the plane landed on the runway  right with me. After landing the plane turned left on taxiway to my right in the screenshot. I got permission to continue taxiing and when I began at odds with the plane to my right, a cras sim.
541
Oh man. CTD when starting right engine on Rotate MD80.
542 (edited by Dewald 2016-05-19 15:36:23)
Oops I did it again la la la la laaaa la la la.
Crash while taxiing to gate at LIRF.
See attached.
PS! I think I caused it as described above w.r.t. holding as per ATC.
543
Love X-Life....use it daily. Also use World Traffic (which may be my problem).
At airport gates I have planes sitting on top of other planes all over the airport. It is because I have WT ENABLED at the same airport? If I UNABLE WT will that just leave X-Life traffic and no planes sitting on top of other planes?
544
probably yes, try it out and you are smarter...
There are some airports that have their own aircraft library you have to remove.
545
Flight from LIRF to LFMN no CTD with Xlife 1.17b and Bluebell aircraft.
At LFMN was cleared to land on 04L with the wind at 300 degrees.  Initial ATIS at LIRF indicated runway 4L will be used at LFMN.  ATIS changed landing runways to 22 R or L.  X-Life did not change designated runway for landing to 22 R or L.  Is X-Life suppose to change the runways based on wind direction?
546 (edited by ilankrt 2016-05-19 18:39:55)
This is an interesting question, how XL program is choosing runways, randomly or based on actual weather data.I got at least 2 times advice to land on RWY in wind direction and several advices to land on RNAV instead of proclamed ILS RWY...
547 (edited by Denco 2016-05-19 19:04:15)
I would really like to buy this product, but first I have a few question.
1. Does ATC use speech recognition and can I use my IVONA voices for it?
2. Why only TCAS planes for atc. Will we ever get an ATC for all panes? This one is the one that is preventing me from buying it since I mostly fly the 737 200.
I would also like to thank you for the free traffic plugin.
Can someone post their pictures on how their bluebell aircraft library and x life are organized?
549 (edited by lanmancz 2016-05-19 20:16:33)
it seems that X-Life ATC is using the captain's altimeter to get the altitude (perhaps also other in-cockpit instruments to get the other data). The problem with this is that if you have an instrument failure (like I had today) the ATC gets stuck without data. While I was able to fly the plane using the FO's and backup instruments the ATC still thought I was at 500ft.
Also, since I already registered to report this :-), I'd like to make a feature request. It would be nice if we would be able to request runway change for takeoff and landing and also request altitude change.
550
I am wondering if you can customize the airplanes you see. I love the add-in but if I could set a certain number of aircraft to each airline, it would be even better.
