651
Goog evening, Pilots! Work on sound engine for XL now last 3 days. Hope will be ready soon. Sorry, rare answer, but read all, anyway.
652
BluesmanEP wrote:
The problem is that the plugin can't decide which runway to use for departure.  It alternates between two different runways very very quickly.  I've tested is using real weather, CAVOK weather, and a manually set weather that is clearly favoring one of the runways.  Always the plugin isn't able to choose a departure.
Thanks, and please let me know how else I can be of help!
No, problem what ATC cant build a rout not for one RW, not for another. A reason? - Need check ATC taxiroites fot this airport.
653
OK,
ONE MORE TIME NOW
READ THIS THREE TIME TILL IT SINKS IN AND THEN READ IT AGAIN.
BECAUSE I DO NOT WANT TO HERE THE WINING,
Please note, what the airports that are present on the X-Life map (https://www.google.com/maps/d/viewer?mi … ecn3NB3GZ8) created with consultation of JAR Group and will be automatically downloaded to this folders from server, when your plugin starts first time. If new airport will be added to map, it also will be downloaded when plugin will start
then these airports work any others you might have issues with if you try to run X-Plane and the Flight Plan part of the X-Life Plugin since, the X-Life plugin is not recognizing the data from the airport in the navigation part of the program.
and most of this as testers you do not even need to know all we want you to do is Test the product and report your findings by sending you log.txt and bbox.txt (for those who are flying JAR aircraft) and any apple Problem reports from CTD's "." and then the reports in detail is that hard I do not think so when the plugin is free.
Thanks Brian! And I should note what airport autors should feel free to contact me direct to
1.supervise ATC-taxiroutes
2.fix details if need
3.publish it to server for all users autodownload
654
BadiBadu wrote:
First of all I want to thank you for this great add-on,  I think it has great potential and makes flightsimulating more realistic specially for people who don't want to fly online.
I noticed that the METAT/Weather information in the ATIS from the X-life window is different then the METAR info displayed in the Jardesign Airbus a320neo Cockpit.
This is confusing,  I hope that this can be changed
Greetings,
a320/330 get report from X-Plane file (it is old if you checkoff realweather option)
XL get actual weather direct from NOAA servers, it is always new
655
marty2756 wrote:
marty2756 wrote:
I'm trying DEMO airports (EDDM to LOWW) and I can't se dexlue features (i.e. radar map). Are dexule features disabled
even in demo airports ?
Deluxe features are not disabled. Not in the demo airports nor in any other airport which has ATC routes.
Maybe you have to switch the deluxe menu on via Xplane plugin  pulldown menu "x-life / deluxe" (or so).
Then you get the green deluxe menu with the icons, and from there you can switch on the radar map, route planner.....
Thanks but, when I click "menu deluxe on" I get a message in green saying "Plaese use payware serial to active deluxe options" (I'm at EDDM airport)
There is no DEMO airports now. All airport (from MAP or custom-build) may be used with XL traffic. Deluxe options will bee work if activated, not depend of airports..
656
nobbymz wrote:
Hi, the ATC window has a text overflow see the HC.
http://jardesign.org/forum/img/m/2265/t … 71me63.png
Norbert
yep, my bad
657
WOW!!! Thank for your work!!
658
Just to be sure... still its not possible to get deluxe features ? (I click "Get deluxe features for xxx" donation button and nothing happens ... in fact goes to x-life home page again)
659 (edited by ilankrt 2016-03-23 13:47:14)
Test flight LIRF - LOWW. A330
After deinstalling v.09.2  I installed again the A330 folder and the X-Life 09.2 folder to check what cause crash.
1.  I made 2 changes. First during APU activation I didn't set passenger warning lights as I used to do, because at this point
the mess with the checklist annunciations began. Second I calibrated device axis in earlier stage before starting engines.
I don't know if this causes the failures of the A330 but it it an issue to think about for JAR....
( Pl. have a look at the attached bbox_log)
2.  During cruise speed reduces suddenly. I had to intervene  -  full thrust, back to speed and AT was again responding.
3.  resuming flight - no XL crash
4. calling FollowMe car - car was "flying on map like craze" Initiating from map directly works.
http://jardesign.org/forum/img/m/1591/t/p1aehq05vthtc5ecqsa1m3meqg3.jpg
660
Hi JAR
Your announced EPWA airport scenery is from 2010 and awful.
There is another much more real free scenery from tdg :
http://forums.x-plane.org/index.php?app … file=24240
Maybe you or someone else will prepare this airport for ATC and traffic...
BTW there is also a profi payware scenery from Drzewiecki
http://store.x-plane.org/EPWA-Warsaw-Ch … html#tab-7
661
Hi Jar, the ATC window has a text overflow see the HC.
http://jardesign.org/forum/img/m/2265/t … o1s0n5.png
Norbert
662
OK,
ONE MORE TIME NOW
BECAUSE I DO NOT WANT TO HERE THE WHINING,
663
Hi JAR,
Thank you for your answer!
Do you know how to get the weather from the NOAA servers into the a320/330??
Best regards,
Greetings,
664
Great News!
665
BadiBadu wrote:
Hi JAR,
Best regards,
Greetings,
X-Plane will do this if you "real weather" X-Plane option turned On.
666 (edited by SirOTheOne 2016-03-24 10:38:28)
Flying from LOWW to LIMC -> CTD, see log
667 (edited by marty2756 2016-03-24 10:59:08)
I will ask again because I didn't see reply for my previous post..
Is it possible to buy "deluxe options" now? If so.. where
668
Metallist wrote:
Good night.
Plugin Version 9.2
Fly on the route ULLI - UUEE. Set in Sheremetyevo STAR LTB06A on the 06 runway and ILS approach runway 24L.
Полет по маршруту ULLI - UUEE. Заход в Шереметьево назначен STAR LTB06A на 06 ВПП, а заход ILS дан на 24L.
Понял, спасибо за лог! Thanks!
What aircraft did you fly with?
Airbus А330 from JAR
669
Test flight XL 09.2 A330 LOWW - EDDT
today I would like to discuss an important point concerning the logic of air traffic during landing.
As I was descending to EDDT I saw on radar another 3 aircraft on the same approach to RWY 26L.
Now landing became exciting, I reduced speed to minimum to gain distance to the aircraft flying in front of me.
It works well but in the last moment the XL air traffic generated another aircraft on my route and I got massage "abort landing" . Although abort landing is a part of good simulation it happens too often.
My advice is to restrict the XL air traffic generator to generate aircrafts for landing in greater distance from runway.
They should appear at minimum distance of 30 nm!
670
Have a look at the Support Link on the X-Life Page smile
http://www.jardesign.org/ticket/kb/faq.php?id=50
671
Yep, found that and bought it a while ago. I guess the "buy button" on main page does not work on purpose because of beta.. Thanks anyway.
672
Yes, something like that for internal logic, but sometime it is still not work.
673
Thanks for log!!!
674
Test flight XL 0.92 EDDT - EYVI A300 iMac
no crash
EYVI airport is a mess. Runways - lack of order, parking lots wrong space, XL aircraft taxi not correct.
FollowMe car to parking lot brought me on collision way with parking aircrafts. Airport scenery needs a
revision!
http://jardesign.org/forum/img/m/1591/t/p1aeldc7ms1ug21vcu1d6l6ipid73.jpg
http://jardesign.org/forum/img/m/1591/t/p1aeldi82tc4c7t11v971g571v3d3.jpg
http://jardesign.org/forum/img/m/1591/t/p1aeldehec1df51mms5ksn7lc1fa.jpg
675
Hi Mr. Romanov,     please read this :-)
There is a really big bug in Flight Plan route calculation (in xlife, A320, A330)
- It is NOT POSSIBLE to calculate a route where no SID is defined in AIRAC Cycle in dep. airport
- If there is no SID defined in dep. airport, it is NOT POSSIBLE to get a complete flight plan in A320 + A330
How to reproduce this bug every time (it's NOT the airport CYXC !!):
- install included airport CYXC
- we try to calculate a route from CYXC to KSFO
1) start x-life
2) hotstart A320neo2.6b4
3) open x-life Flight Plan
4) ENTER: dep: CYXC, arr: KSFO, altern: KSFO, Level: 320
5) Press "Generate"
Result: Nothing, empty flight plan. Does not work. You won't be able to generate a route.
6) in FMC A320, enter: CYXC/KSFO in init page (from/to)
7) switch to F-PLAN
8) set departure and arrival SID/STAR, does not matter what you set.
Result: "Flight Plan Dis." which is not removable.
You can not delete the Flight Plan Dis., regardless what you do.
===> This does not work.
9) Install the included modified_navdata_CYXC.txt in "GNS430/navdata/proc/CYXC.txt", but BACK UP the old version
     (because my modifications are NOT real world, just to show what is going wrong)
     (it's a simple modification, I copied the SID from CYYC and corrected the names. This is logically nonsense,
      but technically your generator thinks that there are valid SIDs at the airport).
10) restart x-plane, goto 1) and restart :-)
Result:
a) Flight plan calculation works now.
b) no more "Flight Plan Dis." in A320 which can not be removed. Select any SID and remove the "Flight Plan Dis."
Conclusion:
==> Route calculation needs to be fixed, FMC needs to be fixed (same bug)  :-)
(don't forget to restore the original AIRAC data backed up before....)
Best regards,
Attachment icon CYXC.txt 295 b, 300 downloads since 2016-03-25
