501
Dewald wrote:
Dewald wrote:
And another one
Sorry -- My x-life.dmp seem to be 6.5Gig
please redownload win.xpl - your .dmp will be 150 Kb
Third CTD
I just downloaded the win.xpl
Will retry
PS! Aircraft --- Airfoillabs C172
Please attach x-life.dmp file (from X-Plane folder)
502
Hallo JAR
is it possible that there is a conflict between Sound Maxx and Blue Sky Star I installed (resp. X-Life sound)?
503
First crash !
2 test flight EDDM - EHAM
Taxi, Take-off, Cruising OK
Crash 2 times during Approach
If possible need information about cause
can I ask you attach MAC OS crash reports too. They are always saved at your computer.
Here the Apple crash report after the second crash:
504 (edited by captbullett 2016-03-14 17:58:48)
Testing the Alabeo C207 Skywagon v3.2
after a take-off and a good cruse with-out the ATC running just to get the feel of the aircraft and the route EGLL/EHAM as the test route and this is the stock GNS 430 and the 530, I am using so, here is the Flight Plan so you can copy and put in to the stock Custom NavData,
//* Output/ FMS/ FlightPlan folder///;
I will try again and use the ATC this next time ... but I think it was a memory issue .
I
3 version
0
1 EGLL 0 51.477500 -0.461400
3 BPK 0 51.749700 -0.106700
11 TOTRI 0 51.775000 0.196700
11 MATCH 0 51.779200 0.250000
11 BRAIN 0 51.811100 0.651700
11 DAGGA 0 51.821900 0.794200
3 CLN 0 51.848500 1.147600
11 ARTOV 0 51.905300 1.425800
11 REDFA 0 52.114600 2.487900
1 EHAM 0 52.308100 4.764200
Attachment icon Apple Repport X-Life CTD using the Alabeo C207 Skywagon v3.2 .txt 60.21 kb, 447 downloads since 2016-03-14
505
Third CTD
Will retry
Fourth CTD in a row.
Files attached.
506
Thanks for your logs, dear pilots. I work to make it stable!
507 (edited by jcdp 2016-03-14 19:06:44)
I have tried to fly from EIDW (Dublin) to EGLL (London Heathrow) but after having started X-Life and tried to generate a flight plan
X-Plane has crashed ... (three attempt ...three crahes ...just after clicking on "generate" )
As X-plane is also installed in an other folder I tried again ...same result at the same moment ...
for other destination it works well .
I have b9 version and airgraft was Eclipse 550.2
Where this trouble could come from , please ?
Ok, I prepare beta 9.1 with some fixes in code (not all, but..)
to update 9 -> 9.1 this 2 files only need to be installed
509 (edited by jcdp 2016-03-14 19:33:51)
I just got ver 9.1 after my previous post ...
After 9.1 installation same trouble generating flight plan from EIDW to EGLL  (X-Plane crashes )
but works for plan between EGLL and EIDW ...
510 (edited by captbullett 2016-03-14 20:05:43)
Ok, so I want you to fly a route EGLL to EHAM, (this is a short control route I fly.) and if you do have any issues you must post a log.txt and .dmp txt ike the other Beta testers are doing please, this is how we fix the issue and the only way you will have a smile on your face.
We work hard to track down the issues here and answers you questions quickly so will you help us by sending your log.txt and bbox.txt if you have a JAR aircraft, if you are using another aircraft then no bbox.txt. look at how others are posting the attachments like post #505 this is how i would like you to post your data.
Thank-You,
511 (edited by jcdp 2016-03-14 21:26:10)
Thank-You,
I shall fly EGLL to EHAM ok and let you know ...
Did you see my post#507 where you have log.txt ?
As I am not familiar with .dmp txt (and I did not find one in X-Plane folder) could you give me the path to find it, please.
Did you see post#507 where you have log.txt ?
it should be placed at X-Plane folder. If not - please check are you install dbghelp.dll file (should be placed in X-Life folder). If not- please take it from distributive.
513
Just to be sure... x-life allows to have other aircrafts in the sky... but talking to ATC to request clearance and such things is a premium feature, and not yet available, is it that?
Oh and I wonder, to use x-life, should we turn x-plane ATC (sound, text) on or off?
Yes, you need a key from the developer and if you are nice and e-mail him he might give you a key. Also, on question 2; leave the x-plane settings alone that is when you have issues, we will be tracking what is going on by watching your log.txt and can give you very good data to help you fine tune you XP and X-Life.
Thank-you
515 (edited by harf4ng 2016-03-14 22:42:13)
Thanks wink
So here is my log.txt file...
In LFMD, it says this is not a verified airport, and I cannot file a flight plan, or see departure info, in fact a lot of menus do not work. They work in LFMN. But i'm more in general aviation, small planes (Robin DR400) and LFMN is too big for me ^^
Moreover I'm doing my real life flight lessons in LFMD ^^
516 (edited by captbullett 2016-03-14 23:03:14)
so, this is a CTD using the A330 and EGLL/EHAM just after take-off and the contact with the Approach the computer had to many contacts and to many things going on just after take-off.
Back to flying Brian and the thing I like to do best LOL.
the debug txt is from the A330 just after the CTD ...
Are we having fun yet,
Attachment icon Apple Problem Report: X-Life: Up-Date 9.1.txt 62.09 kb, 335 downloads since 2016-03-14
517 (edited by captbullett 2016-03-15 01:48:26)
here is the same route that had a CTD just after loading the new version of XL 9.1 and the data;
good flight no issues.
518
Just got thru with a perfect flight from LSZH to EDDH with the JAR A330 and latest update to X-Life. Only thing was that FM car was not available at EDDH. I posted all the logs and a short video of the CAT3 landing. Here's a vid link (3minutes) of the CAT3 final at EDDH for those interested https://youtu.be/lpEe_2FzaCQ
519
that was OpenGL drawing error (X-Plane error i think)
Thread 0:: Dispatch queue: com.apple.main-thread
0   GLEngine                          0x00007fff8a6e9fa3 gleRunVertexSubmitImmediate + 10211
1   GLEngine                          0x00007fff8a6590f5 glDrawElements_ACC_Exec + 941
520 (edited by Dewald 2016-03-15 09:02:51)
Successful flight
SSG 748
Aerosoft EGLL to Aerosoft EDDL
EGLL SID DET L6 DVR L9 KONAN UL607 KOK L179 DIBIR Z282 LMA STAR EDDL
Beta 9.1
I simply insert the flight plan manually. Never causes problems.
521
I followed instructions for X-life folder installation in resources/plugins ...
dbghelp.dll file is in X-life folder ...
but when I got the issue described in my post #507 I only had the log.txt file and you have it with the post #507
I have no .dmptxt file ...
The issue is only when I use "flight plan" from EIDW to EGLL , when I click on "generate" X-Plane crashes ...
As I have installed three different X-plane folders , this happens in all the three ...
I have no trouble with others destinations.
I must say I don't understand how a flight (without trouble) between EGLL and EHAM can help ...
As I see this
XL: 2164 : Flightplan exported to Aircraft: LSZH SID SONGI Y1 TINOX N851 HEUSE N851 LOKTA N851 LEBSO N851 ESULI N851 TEDGO N851 LBU N851 OKIBA N851 ROLSO N851 RIMKI Z99 LOHRE UN851 ARNIX UN851 FUL UN851 MASEK UN851 KEMAD P605 ELNAT UP605 PEXAM UP605 NORTA P605 DLE P605 MADUB P605 AGATI P605 NOLGO STAR EDDH
[SASL ERROR] Error updating avionics: [string "C:\Users\user\Desktop\X-Plane 1045\X-Plane 10..."]:0: attempt to index a nil value
thats mean that you should check what use the same cycle
for a330 here
../X-PLANE 10/Aircraft/330_JARDesign/NavData
and for X-Life here
../X-PLANE 10/Custom Data/GNS430/navdata/
523
As I see this
for a330 here
and for X-Life here
Ahh so! I was under the impression that installing navgraph into the GNS430 took care of all the JAR ac's. So, now I have it in all JAR ac's too! Thank you!!!!
524 (edited by addisonadolf00 2016-03-18 07:23:29)
Thanks for solving the problem now it's Awesome.......
Ivr solutions
*****Hey********
525
Beta 9.1.  Getting CTD just after XP loads.  Using the JAR A320.
Attachment icon bbox_log.txt 118 b, 336 downloads since 2016-03-15
