Topic: v.1.2b4 distributive (Windows 7/8, MAC OS)
Beta
New:
- GroundService (Add small loader now) plugin should work with GPU, DOORS, FUEL well
- FCU push-pull with mouse
- NEW Sasl base plugin (is it stable with MAC)?
- 10-160 NM Range weather radar
Please install it as CLEAR!!! installation, not mix files with other version, but sure, install NavData update if need.
Download link http://jardesign.org/a330/download/inst … _1.2b4.zip
  - be sure, that you use X-Plane 10.36 (No beta, please)
  - copy unzipped «GndServices» folder to ../X-PLANE 10/Resources/plugins/
Thank you!!!!
Re: v.1.2b4 distributive (Windows 7/8, MAC OS)
Ok now.
Need some more activations to continue.
LOL.
Mike
hmm
Reuploaded. Should work.
4 (edited by TurboGigi 2015-08-14 21:04:12)
Thank you my friend, you did an excellent job.
There is only a corrupted file (image fuselage), but I took it out of beta 3. The file is this:
A330JD_1.2b4 \ 330_JARDesign \ objects \ fusel_1.png. The file is damaged.
I just finished a flight from LEBL to LIRF (Barcelona / Rome Fiumicino) and it worked perfectly.
At the start, before starting the engines, I noticed that pressing the buttons: air-conditioning, Fuel, Engine, DOORS, WHEEL, APU, etc. etc., the screen remains fixed on FUEL. This is normal?
Tomorrow I make another flight. With beta 3 the first flight had worked well, all subsequent no ..
No Ground equipment at all....
http://jardesign.org/forum/img/m/552/t/p19snvuse01aeio143p2g841bpe3.png
The only thing i can see is the fuel hose....
testet with xplane 10.36 and 10.40b8 -> same, no ground equipment
So unable to refuel the plane... unable to fly without fuel....
Are you install and use it like this?
http://jardesign.org/forum/img/m/22/t/p19so2n9895tl1vg2dak1imv19pg3.jpg
http://jardesign.org/forum/img/m/22/t/p19so2o7v41kuo1s3idinidetl63.jpg
Will give it a shot later. The new features and upgrades sounds very nice. Keep up the good work. Love to see the A330 evolve continuously.
Karl
error activating aircraft?! What am i supposed to do?
I think you, like me, have run out of activations. Send a mail via the contact form and request a reset! See instructions in OP.
thankss. what do you mean by OP?
11 (edited by Karl Lepp 2015-08-15 11:46:26)
OP is:
Beta
New:
Thank you!!!!
Or the Opening Post in a thread.
12 (edited by WoDi 2015-08-15 14:11:35)
A good job!
The new push & pull rotate is very nice!
Dieter
LEVC-LPFR successful. But the ILS (109.50) did not work. Saw the distanz, but no red marks. Will repeat with another plane resp. another airport. Ground services are great. I already payed for „follow car“ A320. Usable for A330 also?
Dear pilots! How it is stable on Mac?
For me  -  Ok.
Yes, I m on Mac. When my second and third flight on beta4 brings no CTD, I would also say: stable on Mac.
First was crashed?
I could not fly yet I will do it tonight and will let you know if it's stable on mac.
Will test tomorrow
19 (edited by brucekn 2015-08-16 00:22:44)
I had my first flight today with this new beta 1.2b4, no CTD.  This was a simple flight with no changes in flight-plan enroute and with the airctaft started with the "Quick-start" procedure, then FMCU set up.  My only comment is that I never did see a TOD point in the route, although this might be just how I set the flight up.  Good job, J.A.
iMac Yosemite. XP beta 8
20 (edited by Luke173 2015-08-16 00:52:38)
Same here. This wonderful A332 is now officially one of my few very best favourites! big_smile
Standard flight ZBAA - ZMUB, same test route as for the RW Design A333. Sid worked super, Star not so, but I assume it's a lack of data there.
Enjoyed the whole flight, only minor issues, but most important: no CTD!
After parking at the Gate I'm not able to shut down the engines: see pic (Engine Master are off, engines still running)
Thank you JAR for your efforts!
Mac OS 10.9.5, XP 10.40b9
EDIT: forgot one thing: The new mouse mode works very well! But I'd like an option to invert the scroll wheel direction. now its like this: Scroll down: value goes up, scroll up: value goes down. (this might be already inverted by the newer apple mobile macs.. (iPad like scrolling))
21 (edited by captbullett 2015-08-16 03:21:58)
Yes, again A330 and JAR just a cut above when it comes to good design and good code this beta 1.2B4 and the XP10.40B9 so, far is a good match now I need to know how to get the "Ground Service" from the store //*what product am I looking for so I can get the key//
thank-you much,
no problems so far!
push and pull woks great!
Is anyone on a Mac using the Blue Sky sound package?  I have purchased it but didn't want to add any more variables to my test flight today.....
I've tried 10.36 and 10.40b9 no CTD the plugin is stable on MAC!
There is only one thing : after I refuel the plane i close all doors and then when I "drive away" all the vehicles the doors open again so I have to do again "close doors"
Somebody asked about the sound pack I use it I don't see why I shouldn't, has nothing to do with the mac plugin.
thank-you much,
Not needed, for me it works without a license.
FWIW When "calling away" the ground service some doors stayed open too. And closing all doors didn't close them, departed anyway with not paying any attention to it but after landing I noticed the doors where closed.
