Re: CoPilotPlugin for ToLiss Airbus A321
CoPilot plugin for ToLiss Airbus A321 was updated to version 190622. In Fact - it was fully reworked based on Main FCOM/QRH/FCTM changes included from November 2021. So, we create new checklists, procedures and workflow in this version.
27
What was wrong with the standard Checklists.
I've never heard of a "Line Up Checklist" for example.
And so it never matches with the Checklists in your manual.
28
As example "Line Up Checklist" was included for A320 family not a long time ago - please refer "Main FCOM/QRH/FCTM Changes November 2021".
29
does this work with xp12 ? managed to load my 321 but copilot does not show up and or ask me for serial after setup
30
Are you try it with XP12 version of 321?
I checked the x plane org store and neither jd-cpl copilot for toliss aircraft indicate any updates other than initial version.
Where may I obtain the current available version and please get the store to update.
Confirmed I have the latest and I am very pleased with your updated copilot.  Very informative about the process and much more entertaining. IMO.
Haven't found my normal list of problems that I hope are corrected with this version but will report when I do.
Thank you.   Just working on a321 at present.
33
Just one problem discovered with Toliss A321 1.4.1.  Horizontal trim not being set correctly.  Performance wants dn0.3 but jd setting dn0.1
One other problem after line up and wait 'take off' shown but not accepted and as a result chrono not being set.
35
The name LINDA is hardcoded in the Events.  Please update to [NAME].  Thank you.
36
I have the key for xp11, do I need to get another one for xp12?
37
one for both if you use the same aircraft type
38
Version 200922 published. Little bug was fixed.
39
http://jardesign.org/forum/img/m/22/t/p1e7vo7egp15d197jned1cfu1r3k3.jpg
REQUIREMENTS:
+ X-Plane 12.00 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ ToLiss Airbus A321 aircraft Version 1.4 + (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
(actual version 241222, ToLiss A321 version for XP12 compatible)
I have tried to get the version listed here for XP12 (versions 241222) but no matter which download link I use I keep getting version 200922 which says it is for XP11.
40
fixed, sorry
41
YAY thank you thank you thank you, that fixed everything!!!!  She works great in XP12
42
thanks for this info!
