Topic: CoPilotPlugin for ToLiss Airbus A319 (XP11 & XP12)
http://jardesign.org/forum/img/m/22/t/p1e7vo7egp15d197jned1cfu1r3k3.jpg
REQUIREMENTS:
+ X-Plane 12.00 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ ToLiss Airbus A319 aircraft Version for XP12 (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
Pilot job in a modern airliner involves two people. As you are a simpilot, you need someone who can listen to you, execute your command, read checklists, live with you. You can get this with JARDesign Copilot plugin.
She name is Linda. She is well-qualified Airbus A319 (TM) F.O./copilot. She have:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
This product is not refundable, but You can download, install and test the demo version (Manual included) right now http://www.jardesign.org/copilotdownloa … PL-319.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key here https://store.x-plane.org/CoPilot-for-T … _1216.html
SUPPORT: www.support.jardesign.org
Last CoPilot version for XP11 you may download here
http://www.jardesign.org/copilotdownloa … 200922.zip
Re: CoPilotPlugin for ToLiss Airbus A319 (XP11 & XP12)
reserved
Just purchased yesterday and I love this product.  I am hoping with A321 1.03 out now that JD is planning for A321 soon!
It is working very well.  Just have to restart voice recognition occasionally.    Maybe there will be a choice for copilot.
Thank you.
Thank you.
We plan to add procedures for TL319 first. Next - will think about copilot for TL321
Sounds great.   I can't imagine what procedures are needed.
6 (edited by S3rg1o 2020-05-13 13:04:36)
I've tested the Demo, but I removed it, I won't buy it for now.
After removing it I get Linda's face in front of the aircraft suspended in the air!
How did this happen???
http://jardesign.org/forum/img/m/3188/t/p1e87243v91ra31krqup2j5oepg3.png
Plugin have UnInstall function in Menu. May be this function was not used.
Plugin was updated. We just all Procedures and done a number of bugfix.
Many Thanks. Really enjoying this plugin. For me it adds great immersion. I fly in VR and it works great.
Do I just re-download to get the updated version ?
Yes, need just download and install it again.
11 (edited by Michael 2020-06-08 15:12:00)
Hi!
I own this plug-in, as well as few other from you.
Since you've released it, you add more features with the new releases. I love it! I look forward to get the TA321 version, as well as the FFA320.. wink
The download file has always the same name. Is there any way to simplify the update process? An auto-update, maybe, and the for many reasons.
As I said, you don't know which version you're going to install.
Plus, every time I update the aircraft itself, for whatever reason, the 3D copilot disappear from the cockpit. It is still workin though, but I don't see the FO.
Updated to version 160820
HI..I have one problem i have your copilot for zibo and toliss..
With new update toliss 319 v1.5 copilot is invisible,i can hear but don`t see her but that hapen only with new update 1.5 toliss 319 ..before was everthing good ...Did you know for that issue ?I have delete both files and make the new instalation  but its the same problem ..Thanks ...
Best regards Nenad Zunic
When is the last update and what is the final version?
I wanted to let you know I really enjoy working with Linda. We fly together in my A319 and in my B737. She is a benefit to my flying time.
One small thing, tho. I am a woman and she always calls me "Sir." Is there any way to add an option where she can address me correctly?
We will change this Sir -> Cap
Thank you so much!
I discovered how to do it myself!
I edited the copilot_main\data\settings_win.txt (In my case, as I use Windows.)
You can change "sign=" from Sir to Maam or whatever else you might want.
You can change "user=" to any name you want her to call you.
You can change Linda's name with the "name-w=" option.
Will there also be a copilot linda for toliss a340-600 thank you
We plan it will be for XP12 version of TL346
Xp12 is out and even 346 smile I shall not buy the a346 without Linda smile
Any updates for release ?
Sadly, beta 346 for XP12 not have needed options to create CoPilot based on it. So, we just wait for now.
Shame. I have the one for the 319 and used to love the plugin. Hope it is released soon as the 340 is the only aircraft I use on xp12.
24 (edited by Flyboy340 2022-09-28 10:09:29)
Has anyone had any problems with the Flap Setting not being recognised in the Taxi checklist? Despite having the Perf Page flap setting matching the actual flap setting, Linda says that the flaps are not set for take off and cancels the check list. I have tried all flap settings.
Otherwise I think it works very well and is an excellent product.
Please update copilot for a319 to match procedures for a321.  Thank you.
