Re: XP11 JD330 v.3.1 r1, r2, r3
Hallo, ich habe x plane 11 auf einen MAC alles hat funktioniert bis ich gestern Mojawe aufgespielt habe . Jetzt geht der A 330 von JARDESING nicht mehr .
Vielleicht kann mir hier jemand helfen !
Aber eine Bitte hab ich noch! Wenn dann bitte genau erklären weil ich als alter Mann doch nicht so fit mit Computer bin. !
Danke
Um helfen zu können, müssen wir die log.txt Datei sehen. Bitte hochladen!
103 (edited by HKGDRAGON 2019-02-26 04:38:44)
Also make sure you do not have an activation word set in your system to activate dictation. I had this issue on my Mac. Dictation worked perfectly in Word etc. but not in X-Plane. Then I removed the activation word setting and all works perfectly now.
Thanks for the help - much appreciated. YesI unticked the "Enable the dictation keyword phrase" in System Preferences --> Accessibility but still unable to talk to Linda...
Do I need to use a microphone/headset. Currently I'm using iMac. Tried a USB Headset but still no response.
I have checked my audio settings in Preferences. Microphone is working but no response from Linda.
Perhaps I should reinstall and try again...
UPDATE
OK so, I missed the part where I need to assign a button to jd/CommandRec. oops sorry. All worked. So updated all the plugins including version JD330 3r5 from the main website. No more Linda!! Just get a menu Title A330-->Setup. Does Linda still work in version 3r5?
So Linda working well in 3r2 but for the Landing Lights loop she keeps repeating during the approach. Will try the beta version shortly with the all new Linda.
Yeah, always good to RTFM
My recent purchase JD330 is version JD330 V3.OR4
IT'the leatest version ?
Generally how to update the aircraft ?
Thank for your Help
André Gassmann
107
Updates are at the top of this thread
http://jardesign.org/forum/viewtopic.php?id=11342
108
was heist das Log.txt ? vom A 330 oder von dem Mac  ? und wie mache ich das !
Der file Log.txt befindet sich im X-Plane Ordner. Dupliziere oder kopiere es und sende es ....
110
JD330 is updated to version 3.1 release 3
+ METAR reading issue fixed
+ GPU button fixed
+ MDCU MENU Ground Handling operation fixed
Please note what Ground Handling plugin should be updated too from
http://jardesign.org/forum/viewtopic.php?id=4133
111
Thank you for update~
112 (edited by divinglyc 2019-03-08 03:25:19)
http://jardesign.org/forum/img/m/4696/t/p1d5dla6mg157g1v6n1qf21rq0f6t3.jpg
Thanks for the update and it does fixes the GPU button!
However, there is still issue of METAR reading issue for me..
Please refer to my attached picture..
Are you using ASXP? If so, the METAR doesn't read for now.
114
No, I use default weather of XP 11.32.
You must press update, and you see.
116
I did, more than once....
It didn't work......
117
Sorry with my version v3.1r3 vorks fine
1. picture get when you don't set your MCDU and press update knob
http://jardesign.org/forum/img/m/4390/t/p1d5emf1kg1apg1cap14h6r1udb3.jpg
2. When you init flight you get metar data with update knob get data for airport
http://jardesign.org/forum/img/m/4390/t/p1d5emf1khu341tboc27si51mlr4.jpg
118
Thanks for your info.
I actually did the same setting. I have already done all the setting in FMGS.
It worked well before... but now it doesn't....
Hope I can find out why.....
119
Hi, bei meinem Mac mit Mojawe geht der JDS  A 330 und der Aerosoft A 350 immer noch nicht ! Irgendwie ist das ja seltsam da der JDS A 320 funktioniert. Für Tips und Tricks wäre ich sehr dankbar ,ABER BITTE mir richtig erklären da ich nicht ganz so ein Profi bin !
Ach so der A 330 hat ohne Probleme gelaufen vor Mojawe !!!!!!!!
Gruß
Peter
120
Dieses log ist von der A320 und nicht von der A330. Ich würde empfehlen, den Airport Navigator und das Terrain Radar vom Plugin Ordner zu entfernen. Die können Probleme mit den JAR Fliegern machen. Wenn’s dann immer noch nicht funktioniert, alle plugins entfernen. Wenn’s dann geht, einzeln die Plugins wieder zugeben, bis das Problem wieder auftaucht. Dann weißt du, welches Plugin nicht kompatibel ist.
121
Gruß
Peter
http://www.jardesign.org/ticket/kb/faq.php?id=74
122
Problem A 330  !
Ich bin jetzt ein Stück weiter !
ich bekomme den A 330 ans laufen nachdem ich aus dem Plugin den mac.xpl ( exec ) entfernt hatte, dabei erscheint dann Problem beim Plugin und SASL !
der schreibt : Error a 330 plugin not loaded probertly
please heck aircraft installation
Problem A 330!
Ich bin jetzt ein bisschen weiter!
Ich bekomme die A 330 zum Laufen, nachdem ich das Plugin aus der mac.xpl (exec) entfernt habe, es erscheint dann ein Problem mit dem Plugin und der SASL!
Wer schreibt: Fehler bei einem 330-Plugin, das nicht ordnungsgemäß geladen wurde
124
Schaut aus als ob die A330 nich richtig installiert/aktiviert ist. Ich würde die Installierungsinstruktionen sehr genau lesen. Möglicherweise ist eine Neuinstallierung erforderlich.
125 (edited by Oscoz 2019-03-12 00:03:40)
Running this latest version without copilot plugin.
Still missing the following sounds:
"Before start check list completed"
"After start Check list completed"
"Flight Controls Check List not responding by (FO)"
"Parking check List completed"
"Secure the aircraft check list completed"
"Nice Landing"
"Approach checklist completed"
Those are not triggered anymore.
Can you check on that?
Tks
