1 (edited by J.A.Romanov 2015-05-26 20:50:48)
Topic: v1.1b6 distributive (Windows 7/8, MAC OS) (closed)
Trick what was trying not work. So, I close this and we back to beta5.2
v1.1b6 distributive mostly the same b4, but with new base SASL plugin for Tests and changed Lua Garbage collector order.
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
If you have a CTD at MAC, please place reports direct here (log.txt file and MAC crash report). This version build to understand how new mac os SASL base plugin stable on MAC.
Download link /DELETED/
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
2 (edited by zek0 2015-05-25 17:08:34)
Re: v1.1b6 distributive (Windows 7/8, MAC OS) (closed)
1 is on T/D point
2 hot start on runway
Attachment icon X-Plane_2015-05-25-205426_Mac-Pro.crash 79.76 kb, 256 downloads since 2015-05-25
Attachment icon X-Plane_2015-05-25-210109_Mac-Pro.crash 79.58 kb, 247 downloads since 2015-05-25
50-80nm to T/D point
Attachment icon X-Plane_2015-05-25-220526_Mac-Pro.crash 3.13 kb, 249 downloads since 2015-05-25
4 (edited by cyras 2015-05-25 18:29:40)
X-Plane 10.36r1
Description:
The towing vehicle does not connect properly with the Plane..
System Info:
Windows 10  10122 x64
CPU: Intel I7-3970X 5GHz
MB: ASrock X79 Extreme9
RAM: 16GB Corsair Dominator Platinum 2400
Graka: ASUS GTX TITAN Black
GFX-Driver: 352.84
I believe the screen shot of the Load sheet when you first start the simulation will help also determine a lot for the developer ... I am sure he will be able to use that information also.
I am now running v1.1B6 and first flight is EGLL/LFPO I am using navigraph 1505 cycle data and their Cloud maps also to use the SID and STAR's and everything is lined up the way it should the UFMC is working and no error messages in the Developers console... so far...
I see the first issue is //* the DLL is missing:
  [ D:\Spiele/X-Plane 10/Resources/plugins/xDafWings.xpl : Error Code = 193 : %1 ist keine zul‰ssige Win32-Anwendung.
Failed: D:\Spiele/X-Plane 10/Resources/plugins/xDafWings.xpl.  (This file is missing, not a DLL or could not be loaded due to another missing DLL.)
and this is most likely the reason for your CTD , first do you have all your updates done and in place ? windows service pack: windows 7 SP1 or any other service pack? ... or
MS Visual C++ these are just two that i can think of that will cause you issues ...
cyras wrote:
X-Plane 10.36r1
Description:
System Info:
GFX-Driver: 352.84
Flight Control Checklist.
8 (edited by TDPlane 2015-05-26 18:11:39)
Just downloaded and installed the new v1.1b6 on Yosemite. Entered the serial number. Reloaded the aircraft. Quit X-Plane 10.35.
Restarted the iMac and fired up X-Plane with the new A330 v1.1b6. Tried out some exterior views like Chase... CTD.
Attachment icon bbox_log.txt 118 b, 262 downloads since 2015-05-26
Attachment icon X-Plane_2015-05-26-164202_iMacIVYBridge.crash.zip 16.63 kb, 292 downloads since 2015-05-26
9 (edited by captbullett 2015-05-26 17:50:03)
good day
log txt
I am short on words every time I send a report I have to go through a hassle just to submit the report  it won't let me chose the files i need to submit. Then I copy and paste and it tells me the message is to long then it lets me attach files.. the two step process take too much time if I have to do thing two times why?
So if you don't want the reports just let me know and I will stop sending them. but the Sasl needs to be fixed "."
I can´t load A330 1.1 b6.
The last lines in the log-file:
SASL INFO: loading    mcdu_mng
SASL INFO: loading    mcdu_acstat
SASL INFO: "mcdu_acstat"    version info VER 1.1b6 05.15
SASL INFO: loading    mcdu_radnav
SASL INFO: loading    mcdu_prf_to
SASL ERROR: Error loading panel: not enough memory
Version 1.1 b5 works fine but with crash to reloading.
Dieter
Ok, understand. Trick what was trying not work. So, I close this and we back to beta5.2
