1 (edited by J.A.Romanov 2015-05-19 12:40:10)
Topic: v1.1b5 distributive MAC OS new base SASL plugin Tests
v1.1b5 distributive mostly the same b4, but with new base SASL plugin for Tests.
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
If you have a CTD at MAC, please place reports direct here (log.txt file and MAC crash report). This version build to understand how new mac os SASL base plugin stable on MAC.
Download link Temporary removed
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
Re: v1.1b5 distributive MAC OS new base SASL plugin Tests
Hello friends did, the A330 version 1B5 downloaded and re-installed on my system X-Plane 10:35. Unfortunately I can not refuel the aircraft. The truck drives to the aircraft, but there are keinbe option for refueling of Airbus. Tank is empty, systems of course can not be booted so. What to do? Greetings from Germany! Klaus
3 (edited by Luke173 2015-05-19 11:57:04)
Yes, I can confirm this behaviour. Ground Equipment call works, the Fuel Truck arrives, connects the hoses, but the Refuel window vanishes after a split of a second. Several Ground Equipment removes & calls, problem remains.
Manual Fueling is also not possible
Luke
EDIT: Plugin -> LoadSheet does also do nothing (no sheet poping up)
Mac 10.9.5, XP 10.35
CTD while trying to reload the aircraft after a successful activation.
(MAC, XP10.35r1)
Same issues here - ground equipment comes up but the fuel window doesn't appear. All displays stays black after enabling the batteries and ground power...
Please be sure what you are not mix files with other version. Need make clean installation. Anyway i have work refuel well and load sheet too. Will see other reports, please.
7 (edited by Luke173 2015-05-19 12:34:50)
I have a clean installation of XP with nothing but the Laminar Files.
Deleted B4, unzipped B5, made a short Video, following soon.
Meanwhile the "no crash, no fuel" Log Fiel
Loaded: /Volumes/Media 4TB/X-Plane 10.35/Aircraft/Heavy Metal/A330JD_v1.1b5mac/330_JARDesign/plugins/330/mac.xpl (jardesign.a330).
I had no previous installations (bought the airplane today and installed the beta)... smile
Not about X-Plane clean installation, but 330 clean installation.
some strange.. ok, temporary paused this tests and will contact to SASL developers.
11 (edited by Homer.Simpson 2015-05-19 12:56:30)
Clean installation here…
and no fueling and load sheet here either.
Loadshets just pops up and going away and then it isn't possible to open it again
JAR, yes, i know. What I meant to say: I have a clean XP installation without any other addons (scenery, plugins, planes...)
All I do: Add you Zip File, unzip, to Heavy Metal, and give it a go big_smile
Don´t unzip to Heavy Metal. Unzip it to Aircraft!
Dieter
Dieter
I had the plane also installed at "Heavy Metal" folder - moved it to the "Aircraft" folder but unfortunately that doesn't changed anything.
The "Hot Start" button disappears after a couple of seconds. Neither the fuel popup appears nor the loadsheet... And all displays are staying black.
I confirm fuel truck doesn't work and all displays appear black.
16 (edited by J.A.Romanov 2015-05-19 13:47:09)
ok, publish b5.2
should solve black screens
